Question about RCA RP5440 Clock Radio
Converting 120/60hz clock radio to 120/50hz
I HAVE A RCA LCD CLOCK RADIO MODEL RP5412A 120V/60HZ. I WANT IT TO WORK IN JAMAICA WHICH IS 110/50HZ. HOW DO I GET IT TO WORK. I CANNOT GET THE RIGHT MODEL IN YOUR PRODUCT AREA. THE RIGHT PRODUCT MODEL IS ( RP5412)
5 Suggested Answers
SOURCE: bose clock radio Awrc-1p
Call the US tech support line, they will talk you through it.
Posted on Sep 26, 2007
SOURCE: need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: i need to print a manual online for RCA clock radio model RC46
free manual
http://portablemedia.manualsonline.com/manuals/mfg/rca/rc46.html
Posted on Jan 15, 2010
  • 5 Answers
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Posted on Feb 21, 2010
Will a LG LED TV model 42LV3500 bought in Canada work in India
I'm sorry to inform you that the TV is not directly compatible with the power and color system available in India. The TV is only designed to work with 120V/60 Hz and NTSC color System. The power specification in India is 230V/50Hz. The color system is PAL.
However, you can use a Voltage converter and PAL to NTSC converter to make use of the TV in India.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 05, 2011 | LG 42 42LV3500 42 LCD TV
Just bought a Maytag MDB8959AWB Dishwasher (120v 60Hz) and installed it in Jamaica (115v 50Hz)but it does not work. We changed the control board but nothing, no lights or response. I also have two friends...
Hey i am sorry i got disconnected could you please reconnect to the chat room or just post me and i will give you the solution there \
best regards mike
Jan 23, 2010 | Dishwashers
Converting 120v AC adapter to 220v AC adapter
I live in the Philippines, but I've got relatives in the US who send me gadgets as gifts. I've had the same problem with my laptop before but when I called HP call center, they said that as long as it says there input 100 - 240V, then it's ok to plug it in a 110 or 220 socket. Here in the PH, we have 220V sockets, but Americans use 110.
Anyway, your phone says it can only be plugged to a 120V socket (max) so that means, you have to use a transformer (that's what we call it here. a black box-like thing) to convert the volts from 220 to 110. If you plug your phone directly, it might explode.
I hope i answered your problem.
Nov 27, 2008 | Lands Phones
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Clock runaway
You are right on, the clock is using the 50 hertz to keep time expecting it too be 60 hertz.
Dec 27, 2007 | GE RP4842 Clock Radio
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
SOny Clock IC492 looses time
Dont think this model clock accuracy depends upon the supply frequency.
1. I have ICF C 318 with the same specification but works accurately (1 sencond) in 50 Hz.
2. there are some amazone complaints even from US (wherein 60 Hz exists)
3. Dont think a clock designer will depend on supply frequency. (many time, this varies even in a very good power network)
Jul 15, 2007 | Sony ICF-C492 Clock Radio
JCR-160 clock radio Clock running slow
The clock works off the frequency (hertz). In US the electrical wave frequency is 60HZ/sec and in India and many other countries 50HZ/sec. Hence, the clock slows down about 6 seconds or so every minute.
Mar 12, 2007 | Jensen JCR-425 Clock Radio
Bose clock radio Awrc-1p
Sep 15, 2006 | Bose Wave Radio
RCA RP5440 Clock Radio Logo
197 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
