Most functions work fine i.e sound for the T.V but when you push the power button to standby the system just flashes 'standby'. Also if you try to switch to DVD mode either by using the function button or inserting a DVD the system just goes blank with nothing lit.
Only way to get it working in both cases so I can get sound for my T.V is to switch off then on at the socket.
Any help would be great.
Comments:
May 20, 2006
- Thanks for your help Techman. I just wanted to give you more info on my problem.
I can use all functions. TV, video 1, video 2 and Tuner. If i select DVD then the display shows 'DVD' for a second then goes blank. Press the function button gets you back to the other functions ok.
Also if the standby button is pressed then i get the flashing standby message until i power off then on at the mains.
I thought the DVD drive module might be at fault, so i tried it with the DVD module disconnected but was left with exactly the same fault.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Comments:
May 20, 2006
- If you disconnect the CD Deck and it does the same thing then I would assume that theres gotta be a problem in the microprocessor curcuit.
Hi, my Sony DAV-SC8 DVD player will only play DVD's for approx 1 hour then it will start to freeze...
(More)
Hi, my Sony DAV-SC8 DVD player will only play DVD's for approx 1 hour then it will start to freeze and skip. When I try to turn it off it flashes standby for a few minutes then eventually switches off. It will work for hours when I'm using it to watch TV with surround sound but the dvd function will always freeze after an hour or so. Any ideas guys? Thanks.
connect a panasonic lcd tv TX-37LZD800 TO A panasonic blueray freesat recorder DMR-BS850EB TO A SONY...
(More)
connect a panasonic lcd tv TX-37LZD800 TO A panasonic blueray freesat recorder DMR-BS850EB TO A SONY audio DAV-SC8
I get no sound when playing a finalized DVD+R disk through by Sony AV system. DVD plays fine in my...
(More)
I get no sound when playing a finalized DVD+R disk through by Sony AV system. DVD plays fine in my computer. Suggestions?
I have SONY DAV-SC8 System 2 questions: 1) how can I connect my MP3 player to my system - there is...
(More)
I have SONY DAV-SC8 System 2 questions: 1) how can I connect my MP3 player to my system - there is no AUDIO-IN slots or any USB on Sony DAV-SC8 2) Can I connect BOSE outdoor speakers to my Sony system
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
