Question about GPS
MY GPS WILL NOT LET ME GO TO MENU OR FIND WHEN I TOUCH THE SCREEN IT WANT DO ANYTHING I GOT LOST YESTERDAY BECAUSE OF THIS NOT WORKING DONOT HAVE MY BOOK
  • ghalebhenry Sep 11, 2008
    I own a gps invion 4v222-ide
    Unable to go to menu,instead,when I click on navigation,the following message appears:The system can't find navigate the software in the flash,please check it,then re-start the system.
    Any solution or do I have to return the my gps to the manufacturer?
I own a gps invion 4v202
Posted on Dec 19, 2008
My nevi 2595 shows only touch dot and will not do anything else. If you touch it the dot moves to another area on the screen
It looks like you are in the calibration mode ... just touch every dot and after a few times it will go back to the menu ... as usual.
Dec 24, 2014 | Garmin nuvi 2595LMT 5" GPS w/Lifetime Maps...
Touch screen doen't work
If there is a PIN assigned and the PIN can't be entered in because the touchscreen isn't working, then the PC will not recognize it. The communication routines between the Nuvi and PC will only happen after the PIN has been entered. If your at home, you will get to the main menu because that's your safe location where it will not ask for a PIN. The touchscreen is bad and needs to be replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jul 26, 2010 | Garmin Nuvi 660 GPS Receiver
My GPS just stopped responding to touch.
can you soft or hard re-boot your GPS?
(usually by holding down the down button + menu)
Jul 02, 2009 | GPS
GPS touch screen sprayed with Windex; doesn't work.
After reading sharcnet's reply yesterday that putting the unit in the freezer was absolutely the wrong solution, I was very panicked! However, once the unit thawed out it worked fine. We tried the freezer because we've used that tip before to "freeze-dry" cell phones that got wet. Luckily the LCD was not damaged & everything is working fine now. And my husband knows not to spray Windex on any electronic screen!
Jun 01, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 2720 lost sound
do not buy any this product garmin does not warranty or stand by its products, if have this fixed it will cost 300 but if you buy a new gps it will cost 150.00 can you understand this ?
May 09, 2009 | Garmin StreetPilot 2720 GPS Receiver
Touch screen wont work
Try resetting the unit. Oppisite side of on switch (left side) lift rubber cover, notice the button and slide switch. With unit on,use a pen and slide the switch up and then back down and trhen hit the button on top. that should rest the unit. Also you look in the manual for reset.
Apr 04, 2009 | Magellan RoadMate 2000 GPS Receiver
Screen is black
Most likely you will need to do a re-set. Just slide the power switch to the left for 8 seconds. It should then re-boot. It this doesn't work, you've got more serious problems.
Jan 01, 2009 | Garmin nuvi 780 GPS
My tomtom is not responding when I touch the screen
Use tip of Pen with ink cartridge stored. Large fingers do not work.
Nov 13, 2008 | Tomtom ONE GPS Receiver
Touch screen is not working
Calibrated the touch screen, that fixed the problem.
Thanks
Jul 28, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
164 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
