Question about Harman Kardon AVR 5 Receiver
Receiver power problem
After a power jump( like a short "wave" of voltage that's higher then normal) occurred in my house the receiver stoped working and wont turn on at all. when i connect it to a power source it smells like something is burning. I opened it and couldn't see anything that seemed burned. what are the odds i could fix it myself by changing a fuse? do I have to take it to a repair lab? Oded
  • Anonymous Mar 25, 2014
    no burning odor.just wont power up
    President:
  • 3,130 Answers
If you smell something burning its about 99.9% sure that there's permanent damage to the power supply and unless you know how to troubleshoot electronic curcuits it would be best to take to a pro or contact HK at harmanaudio@harman.com good luck
Posted on Apr 23, 2006
Replace 15 amp fuse to a 30
NO,NO,NO ! Fuses are electrical protection for the cars wiring installing a higher amp-age fuse takes longer to blow so your wiring gets hotter and starts to melt the insulation and shorts to other wires eventually burning up the harness. With a amp meter test the circuit to see how much power is needed to keep the circuit going if over rated (15 amp circuit taking 20 amps) then install a cycling circuit breaker 10 amp this will blow and cool and blow again continually then with a magnetic amp meter (Gauss meter) you can locate your short the source voltage causes the amp meter to jump as the fault occurs when you pass it meter will stop working.
Apr 22, 2014 | 2002 Ford Escape
PROTECT does not come out from the screen
Check the speaker wires for shorts or damage. If none, the amplifier has faulted and will likely require service to restore back to normal working condition.
Apr 11, 2014 | Audio Players & Recorders
What's the difference between a surge and a spike in voltage?
A spike is an increase in voltage for 1-2 nanoseconds.
A surge is the increase lasts 3+ nanoseconds.
Feb 05, 2014 | Electronics - Others
We have 3 exrox phaser 3600 printers and all are showing adc errors. We cycle power, but eventually they re-occur, and at the most inappropriate time. What can we do to resolve this? We replaced HP...
By recycling the power you are allowing something to cool or in this case discharge. I would go into the circuitry and look for a Capacitor that was bulging on top or the cover had shrunk on it. Sounds like when you remove the power it is allowing the capacitor to discharge, then when it runs for a while and gets fully charged it is causing a thermal runaway or something to run off frequency if it is in a wave shaping circuit. At any rate I think you will find the problem to be on your electronic circuit assembly. If you can access the circuitry I suggest you get a can of freeze spray and run the machine with the circuitry exposed and when the error occurs start spraying the IC's one at a time. If it is a thermal run away the error will go away immediately once the cold spray hits it. Then look for Capacitors that look as I described earlier. If the spray clears the error then the capacitor will probably be close to that IC. However, if you see any capacitor that show signs of damage by all means replace it. I firmly believe that this is where your problem lies and you can pick up the Capacitor at any electronic parts house, just to be on the safe side I believe I would get a Capacitor with a little higher working voltage and a higher micro farad rating. Unless it's in a wave shaping circuit then it will have to match exactly. I hope you have on staff or know a good electronics technician. dhgill1949
Sep 01, 2011 | Xerox Office Equipment & Supplies
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Speakers work at low volume. Around -39 db, receiver shuts off.(protection mode) Tried moving speaker wires, alternating red and black. No go. When powered back up, display says ck sp wires. Once I...
Decibels correspond to the output voltage being sent to the speakers. In your case, the voltage is reached at -40dB is the threshold that causes whatever is happening to operate the receiver's protection circuit. You might have a bad speaker, with a voice coil that shorts at the higher voltage. Below that level it's okay, but at the magic point the insulation breaks down, and that's when the receiver sees trouble.
You might try connecting only one speaker at a time using a short length of wire other than your current ones. If the trouble occurs on one speaker only, you've found the culprit. If the receiver operates normally on each speaker, try reconnecting one speaker at a time to determine if one of the speaker wires may have a short somewhere. There might be a weak spot in the insulation, not causing any trouble until the voltage is high enough.
If the receiver still goes into protection with just one speaker, there's an internal problem. Some part in the amplifier may be breaking down at that voltage. Or a part value has changed, causing the protection circuit to kick in even though there's really nothing wrong. Bad solder connections may have developed. Unfortunately, this kind of problem usually needs the services of a shop with the equipment and circuit information to figure out what's happening. If you can find a Yamaha-authorized warranty servicer, they might already know some typical causes if they've seen units with the same trouble.
Try the speaker test first. Then let a shop tackle the receiver if it looks like that's where the fault is. Good luck and thanks for using Fixya!
Jun 03, 2011 | Yamaha HTR-5830 Receiver
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
What is the maximum amount of electrical energy that can be delivered durning a short circuit for low voltage 230v/400v
Tom, Not sure if what you're asking relates to the Maximum electrical energy (Voltage and Amps) that can occur during a short circuit through a properly protected electrical circuit (protected by a circuit breaker, etc.) or if the question is for the maximum amount you could potentially get from a short circuit on a 230V or 400V electrical line to ground OR another electrical line/supply.
IF the circuit is a 230V-AC circuit protected by a double circuit breaker, you could see the entire Voltage (230V-AC) and up to the full Ampere rating of the circuit breaker, (20, 30, 40, 50, etc Amps) during a short circuit condition to Ground.
IF the circuit is a 400V-AC circuit protected by a double circuit breaker, you, again, could get the entire Voltage (400V-AC) and up to the full Ampere rating of the circuit breaker protecting the circuit, when shorted to Ground.
Now, IF the short condition involves one of the above line voltages AND you are having it shorted against another Voltage/Amp circuit, the total potential Voltage and Amps you could experience, would basically be the sum of the two Voltages (and Amps) of the two (2) circuits being put into a short condition. So you would/could see a potential short circuit of whatever voltage is available, depending on what and where the short circuit is occurring.
By way of example, I've seen a 240V-AC 60 Amp circuit shorted to another 240V-AC 60 Amp circuit and the resultant "short condition caused enough damage, due to the voltage and Amps provided, to melt and weld the machinery's electrical connections, rendering the unit a total loss, not to mention that the person that caused the short to occur, received a face-full of melted copper metal bits all over their face and body. Thankfully they were wearing safety glasses, and their eyesight was saved, albeit, with some temporary blindness caused by the extremely bright flash and explosion.
The examples provided assume a properly working/functioning circuit breaker protection. However, if the circuit breakers are faulty, it is possible to recieve much higher vlotages and Amps, since there would be no protective circuit breaker that could trip the power off. In that case, the Main circuit breaker becomes the fail-safe protective device and that could have a much higher Amp rating, thus the maximum Voltage/Amps would be limited by the Main electrical ciruit breaker and electrical supply available at the location where the short circuit occurs.
This could be MUCH higher Voltage and extremely high Amps, depending on the situation and equipment involved.
If you have more information about the particular situation, please post a follow-up comment and I'll provide you with some more info.
I hope you find this Very Helpful and best regards!
Nov 17, 2009 | Square D Qob120 1pole 20amp 120v Circuit...
Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Jun 28, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Harman Kardon AVR 5 Receiver Logo
232 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
