Question about Refrigerators
Aeg santo fridge/freezer, no frost electronic. Hope you can diagnose my faulty fridge/freezer. The Fridge sometimes gives an audible beeping warning and the warning lights flash inside.I have to switch the fridge part off using the control switch panel inside , then switch it back on for the fridge to start up again. Do you have any ideas regards Dave Ward
  • 4 more comments
  • Anonymous Oct 30, 2008
    I have the same Problem. What have you fixed?
    Greetz Egon
  • pete_709 Jan 07, 2009
    I ve got 2 of these AEG Santos and BOTH have this fault,Currys service agents have been out 5 Times since October and they are still FAULTY.
    they are coming out again next week to try again to fix both but i'm getting no joy only BUCK PASSING. The only way as I can see to safe guard you
    food from defrosting is to put a electronic timer on the fridge/freezer to
    switch it off and then on ONE MINUTE this will switch off the 3 lights and restart the unit if you program this to happen 3 time per 24 hours this should stop the unit from defrosting as it states in the user book that if the
    door in not open goods will be ok for 12 hours. I KNOW THIS IS NOT THE ANSWER TO THIS PROBLEM BUT IT MAY JUST KEEP YOU GOING TILL SOMEONE COMES UP WILL A FIX. I'm going to the office of fair trading next week if the next call out does not fix this problem for good as
    I THINK THERE IS A INHERENT FAULT AS I'VE GOT 2 WITH THE SAME FAULT AND BOTH STARTED TO PLAY UP WITHIN WEEKS OF EACH OTHER,
  • juliancwhite Feb 25, 2009
    Hi. I appear to have the same problem with the AEG Santo. Basically, the fridge does not go cold. The freezer functions well but the fridge does not go below room temp.
  • howard007 Apr 11, 2009
    I have exactly the same problem. I would be very interested if you find a proper solution.
  • Anonymous May 04, 2009
    as already described + i can't find the instruction manual
  • January23 May 13, 2009
    I have this same problem!  I don't understand from the other posts how to fix this.  Can someone help me?  The beeping is making me nuts.
Thanks but i've fixed the fault
regards
dave
Posted on Sep 14, 2008
  • Luminus Nov 30, 2010
    I just posted this solution on another question:
    We have the same fridge, and I could not find my model either!
    The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
    This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
    We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress and hold the same button. That´s the quick fix.
    To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
    Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG onhttp://www.electrolux-ui.com:8080
My AEG Santo freezer is leakin water on the floor every few days. There is also a build up of ice inside the bottom of the freezer, even though we very recently defrosted the freezer. This fridge/freezer...
try pulling out the fridge very slowly, any signs of hard resistance than stop. there should be a main water shut off back there. if still uncomfortable with this you can always shut the main water off to the house before trying. hope this helps.
Feb 22, 2013 | AEG Santo 7085 KG Side by Side...
Constant build up of water at the bottom of the fridge - what can I do to solve the problem
Check if the pipe or hose that supply water for the ice maker is not leaking. Look in the back of the fridge at the bottom part to see if frost is building up on the pipe then melting and putting water on the floor. Build up of frost on the line indicates low on freon or something is wrong with the fridge. It will still get cold but the frost will melt and put water on the floor.
Jun 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Dec 11, 2007 | AEG Refrigerators
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
Refrigerators Logo
1,932 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
