Question about Kenmore 63942 Dryer
Low heat on kenmore dryer model 417.97802790
Dry works 'ok' . The dryer produces heat but not like it used too. I takes 1.5 cycles to dry a load of close.
The vent is very clean and no obstuctions.
I figured its the heater thermostate or baffle heater but which one? Or I could be wrong and it something else.
  • kenmarshall3 Sep 17, 2008
    I double check and the dry vent is clear and forceful. It seems that I have hardly any heat now and the air is cool coming out the back. It has actually lost warmth since I posted the problem.
    I have looked up the manual on and it doesn't list a heat element as a part just a heat baffle and thermostat. I'm mechanical incline but don't know which part to replace or how to test the part . I assume I would start with the thermostat.
    Any help would be great.
  • 5,911 Answers
Have you checked the dryer exhaust all the way to where it exits your home? Many consumers assume that "cleaning the vent" means cleaning the lint trap. The dryer exhaust vent needs to be clear all the way to the point where it exits your home. The following link provides some good advice on dryer maintenance and common problems:
I hope I'm not insulting your intelligence, here. This is not to assume that you do not know anything. I try to be thorough, because some people just simply don't know. I would pay particular attention to paragraph 3 in the link and follow the advice to determine if you indeed have a ventilation problem or a component that may be going bad. Remove the vetn hose from the back of the dryer and attempt to dry a load and see if you have better results. If the clothes dry quicker, you know you have a clog EXTERNAL to the dryer. If the results are the same, check to make sure the air flow is forceful coming from the back of the dryer. If it is weak, you still may have a clog near the blower fan housing INSIDE the dryer. If the air flow is forceful, but cool, then you may have a component in the heating circuit going bad. It's easier and less expensive to clean the ducting, than it is to assume you have bad parts. If you have already made the determination that you do not have an air flow problem, please post back and let me know and we'll take it from there. I hope you find this information helpful.
Posted on Sep 13, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 17, 2008
    Go to and type in your model number. There is a complete list of parts with exploded view illustrations to assist you in locating the part(s) you need. There are two thermostats listed under the "Motor/Blower/Thermostats" heading. Items 14 (part #5303206879) and 15 (part #3204307) are the Heater Thermostat and Thermostat Control. The Heating Element is listed under the "Dryer Assembly" heading as item number 15 (part #131475300). Item number 33 (part #3204267), is the Thermal Cut-Out - this is the most comon failed item when it comes to heat related problems. The TCO acts as a fuse and will open in an overheat condition. It must be replaced is bad.
    Did you read through the link I provided? In your dryer, more commonly the Thermal cut-out and/or heating element go bad. These components are located behind the drum. You will need to disassemble the dryer by removing the top panel and drum to get to them.
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
I have model # eed4300tq0 it takes 3 times longer to dry than it use to. it use to dry in one cycle on high heat,now i have to use high heat 3 times to get completely dry. dryer is only 1 and a half years...
Blocked vent hose . Disconnect the hose from the dryer and dry a load . If dryes ok , check the vent hose and vent . Make sure there is good air blowing out the back .
Aug 08, 2009 | Estate TGDS840JQ Gas Dryer
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
