Question about Panasonic NV-GS75EG Mini DV Digital Camcorder
USB connection to my PC
I'm supplied with installation CD which is not compatible with Win XP. From where can i get a installation program to make the camera compatible to Win xp. regards. ajay
  • 1 more comment
  • ajay kangat Apr 25, 2006
    Model NV-GS75 not listed among the camcorders for which Win XP installation is available. Is there any equivalent model?
  • gatti Nov 11, 2007
    Whwn i connect my NV-GS75 to my PC i require a driver that's not present in my windows database of drivers, where can i download the same.
  • Anonymous Mar 25, 2009
    USB IS CONNECTED TO MY COMPUTERS HAVING WINDOWS VISTA BUT I DON'T HAVE INSTALLATION CD
I lost my cd so what i do?
Posted on Feb 16, 2008
  • 513 Answers
Hi http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=CamcorderDownloads good luck
Posted on Apr 25, 2006
  • yoav kleinfeld
    yoav kleinfeld Apr 29, 2006
    Sorry, I misread your model.
    Unfortunately they don't keep archives in the site, just updates.
    Try contacting pana. there are also some sites on the web that archive installation software, most ask for a membership fee.
    Good luck
Cc4 108 0000a420
Right click the install icon
Select properties
Select compatibility
Select to run the install program in Win XP compatible mode with admin rights
Thanks for the opportunity to help and please rate this post.
Kenneth Calhoun
Feb 18, 2014 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Ebookman EBM-901 not being recognized as connected on Windows 7 x64. Windows troubleshooting says USB Virtualization stub has a problem, suggests reinstalling, attempts that, then says it failed to fix...
Welcome to FixYa!
Install the drivers supplied by the manufacturer in Windows XP SP2 compatibility mode.
First, restart the computer is clean mode. The Clean Mode temporarily disables all the programs that are being loaded during the startup of your computer.
  • Click start.
  • Type msconfig in the search box.
  • Click on msconfig from the results.
  • System Configuration Window will open.
  • Click the Service tab.
  • Check the box that says Hide all Microsoft services on the lower left corner of the window.
  • Uncheck all the boxes in the list.
  • Click the Startup tab.
  • Click on the Apply button.
  • Click the OK button.
  • You will be prompted to Restart.
  • Click Restart.
Install the driver in compatibility mode.
  • Locate the driver installer file (Application file with .EXE extension)
  • Right click on it. Click Properties.
  1. Click the Compatibility tab.
  2. Tick the check box that says Run in compatibility mode for.
  3. Choose Windows XP SP2 (Service Pack 2). Do not choose Windows Vista.
  4. Tic the check box that says Run this program as administrator.
  5. Click Apply.
  6. Click OK.
  • Connect the EBM-901 to the computer.
  • Double click the driver installer file to start the installation.
  • You may be required to restart after the installation.
Thank you for using Fixya. Have a great day.
Jas247
Jul 21, 2011 | Franklin Electronic Publishers, Inc....
FocusBT 1633 scanner will not scan. Windows XP says USB device is unrecognized. Owners manual indicates there should be an installation CD included for proper driver installation but Honeywell support...
win xp is a far outdated os and may not be compatible with the scanner
click on scanner properties and then the compatibility tab and see that the small square is ticked and then high light win xp as the OS
If there is no win xp , it will not work
if all is there then get the honeywell web site open and down load the driver for that scanner
Jul 30, 2017 | Metrologic Instruments...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
Setup did not find any hard disk drives installed in your computer. Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration...
you didn't post the make and model of the system, but on most modern systems, this error occurs when the Hard Drive Controller for the system doesn't have a native driver on the Windows install CD. So you need to load the driver during the install. In XP this is done via a Floppy Diskette (XP setup will not recognise a USB Drive) Vista you can install from just about any drive (USB Flash drive generally easiest)
Mar 19, 2010 | Computers & Internet
I have just got a samsung jet but can not put the soft wear on to my pc
to install your software to your pc, NPS, try to follow these steps. please take note that you don't need to connect your phone first during installation. if your phone is connected to your pc, disconnect it.
for xp operating system:
1. insert the cd to your computer...
2. enable autoplay for your cd / dvd rom drive
3. select appropriate language
4. select ''install pc suite''
5. once finished, select the finish tab
for vista operating system,
>>do the same as the above steps, if ask to run as administrator select yes.
>>after installation, uncheck run pc studio automatically after finish.
>>select install usb driver
>>click yes if prompted to run as administrator,
>>after installation, remove the cd, run NPS, and connect your phone.
>>if your phone can not be seen by NPS, do these,
on your NPS, click menu, select settings, select connection, check usb cable com1 or com 2 port select ok, and let your pc studio recognize your phone.
for windows seven, though the NPS doesn't support it right now. you can do the following tricks,
1. insert the cd, don't enable autoplay
2. browse your NPS cd, look for the setup for NPS..
3. once located, right click the setup.exe, select properties,
4. select compatibility,
5. check run in compatibility mode on win xp, win vista.
6. check run as administrator
>>during installation, if prompted that the installation was not successful it will give you an options, select install with recommended settings.
the trick also, if you can't install your samsung studio, you may do these...
on your phone, press menu,then select settings, select phone settings, scroll down and it will give you pc connections, select ask on connections, save and exit.
now, connect your phone to your computer, it will ask you what connection do you prefer, on your phone, press memory card, it will install your memory card as mass storage device, open it your my computer, you will see your memory card there, you can now, drag and drop files from your computer to your memory card.
there you go, hope this will help you so you can enjoy your jet.
regards...
Mar 08, 2010 | Samsung Jet S8000 Cell Phone
Can't install USB driver for a Lenoxx EasyCap VC35 on 64bit Win7
Usually they are NOT compatible with WIn 7 Here is how to Install them so they MAY work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all. Always install as Administrator too. do that for the Install and to Run the program too.
Mar 06, 2010 | Computers & Internet
Webcam installation on pc with windows xp home sp3
webcam driver is not compatible win xp
win xp is not longer by Microsoft and drivers and software is no longer acceptable for win xp
Dec 09, 2017 | Microsoft LifeCam VX-3000 Web Camera
Lost restore dvd supplied with computer.have no choice but to restore
On eMacines, the recovery partition contains your driver and software. But you needed to create the recovery cd set when you got your computer.
To restore it,if your computer came with XP, borrow an Win XP cd (cannot be a HP,Dell etc).
Try a repair first:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If a repair does not work, do a complete install.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 18, 2008 | E-Machines Computers & Internet
Connect laptop to cpu and use laptop as monitor
go to "tiger direct" and purchase a usb to usb interconnect cord. the software they supply will install an ansi and unicode driver so you can use two machines with win xp, win me or win 98. xp and me use the unicode driver while win 98 uses the ansi driver.
Dec 27, 2007 | Compaq Presario 5000 PC Desktop
Panasonic NV-GS75EG Mini DV Digital Camcorder Logo
183 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
