Question about Whirlpool Refrigerators
We have a Whirlpool American Fridge freezer, model no. S20ERBB2V. The fridge is getting to cold and has started to freeze certain foods. We have the fridge set to 6 degrees which is the watmest it will go, this makes no difference. Regards Paul
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi paulmac437
I'm Harvey the Master Plumber.
You would like to know what to do if the fridge is getting to cold and has started to freeze certain foods. You have the fridge set to 6 degrees which is the watmest it will go, this makes no difference.
You have an electrical problem. Most likely a bad thermostat. If it is under warranty you're covered! If not then you need a local pro. I do not recomend "do it yourself" on this. It can become very dificult to properly diagnose and expensive to start replacing parts. The local pro will have the diagnostic equipment and knowlege to solve this and it will come with a guarantee, no handyman allowed in this case.
If the fridge is old it may be best to buy a new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool American fridge freezer FRSB36AF20/2 Triangle Warning light on and freezer not freezing. Fridge ok
Most common these symptoms point to a unit low on freon. The fridge gets its cold air from the freezer. So there is just enough freon for a good fridge temp but not to freeze water in the freezer.
Second would be the coils froze over due to the defrost circuit not working. Also check the conderser fan in the freezer. The cooling fan in the back bottom, if there is one, may have quit also.
Sep 27, 2014 | Refrigerators
Why is my refrigerator is too cold food freezing ?
the door between the freezer and fridge that allows cold air to flow from the freezer to the fridge is likely stuck open,,,
Aug 30, 2014 | Whirlpool Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
MY 9 YR OLD FRIDGE IS FREEZING MILK, JUICE AND ALL LIQUIDS IN THE MAIN COMPARTMENT BUT NOT NECESSARILY ON THE DOORS
you gotta send model number,there are different things that can cause this,if the freezer is on top,the cold air from the freezer gets blown into the fridge in the center of the top shelf so if any food is near this it will freeze if the air isn't monitored, check the settings first,it could be set to high, there's a cold control or thermostat that monitors how much air comes into the fridge and when it reaches a certain temp it shuts off but it sounds like your having a problem with it,also on some fridges they have a damper that can mess up,there's a door on it that doesn't close and the cold air just keeps coming into the fridge and things start freezing up
Dec 24, 2009 | Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerators Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
