Question about Panasonic TH-50PV30 50 in. Plasma Television
My panasonic plasma TV
Ok check this out. I have a 50in plasma tv.(panasonic) and i have a HD cable box and it had the components wires in. (red, green,blue). Now i upgrade my box to a
D.V.R with HDMI wiring and when i watch espn i get the burning affect of the logo, which i didnt get with the component wires.
whats the differents? why with one and not with the other? I have had the tv for 6 to 8 months.
  • 3 Answers
Have you considered HDMI version capatibility problems across the different equipment?
To know more about HDMI versions, wikipedia could be helpful.
Posted on Sep 29, 2008
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Just bought a 42" panasonic
On your remote, click menu, then setup, then external devices, then input labels. Here is a link for manual:
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
Dec 09, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Red light flashes 7 times on a 50in th-50pz80b
Unplug main cable from power supply to sc (bd on left) then plug in and try power long enough to see if stays on.. that would prove the sc sustain bd. is bad. If not suspect d bd.
Nov 09, 2010 | Panasonic TH50PZ80BCAB 50 in. HD-Ready...
I've a Panasonic 42' Plasma tv purchased recently and when I connect my Comcast DVR box via Composite A/V connection, I see only black n white images..
Be sure the 3 video wires are color matched on both ends. Try a different cable. Connect another device like dvd player to that same Component input if it's ok then cable box is the problem. If still B/W then replaced a/v or main board.
Nov 23, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-50PV30 50 in. Plasma Television Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
