Question about JVC RX-7000V Receiver
JVC RX-7000V Shortly after turning on my receiver, the display flashes the message OVERLOAD. I have the voltage selector set to 110, however this unit seems to have been purchased over seas, it has the European style plug. Which component could have fried?
  • Anonymous Jan 28, 2009
    My unit does this even when the receiver is hooked up to nothing. I have a JVC mini stereo in for repair that does the same thing.
    President:
  • 3,130 Answers
As per the instruction manual the overload is there because of high volume condidtions and your over heating the unit. They recomend to turn down the volume shut off the reciver wait a few minutes and turn back on the unit with lower volumes. Second it states that the peaker wires or speakers could be shorted so make sure the speakers are good and the wires when you connected them to the reciver are not shorted. If all is hooked up properly then you have a problem in the output stage of the amp and its gonna need service unless you know how to replace the defective output devices? If not Go online at the addy I give you to find about service parts or service manuals.. Good Luck http://www.jvcservice.com
Posted on Apr 23, 2006
How do i factory reset my Harman Kardon avr 55 receiver
Troubleshooting Guide
Processor Reset
In the rare case where the unit's operation or
the displays seem abnormal, the cause may
involve the erratic operation of the system's
memory or microprocessor.
To correct this problem, first unplug the unit
from the AC wall outlet and wait at least three
minutes. After the pause, reconnect the AC
power cord and check the unit's operation. If
the system still malfunctions, a system reset
may clear the problem.
To clear the AVR 520's entire system memory
including tuner presets, output level settings delay times and speaker configuration data,
first put the unit in Standby by pressing the
System Power Control button 2. Next,
press and hold the Tone Mode 8 and the
FM Mode Selector ^ buttons for three
seconds.
The unit will turn on automatically and display
the RESET message in the Main
Information Display Y. Note that once you
have cleared the memory in this manner, it is
necessary to reestablish all system configuration
settings and tuner presets.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Jan 05, 2017 | Harman Kardon Audio Players & Recorders
Standby mode
When the STANDBY indicator
flashes
Immediately unplug the power cord
and check the following items.
• If your unit have a voltage selector,
is the voltage selector set to the
correct voltage?
Check the voltage for your region,
then make sure the voltage selector
is set correctly.
• Are the + and - speaker cords shortcircuited?
• Are you using the supplied
speakers?
• Is anything blocking the ventilation
holes on the rear of the unit?
After checking the above items and
fixing any problems, plug in the power
cord again and turn on the unit. If the
STANDBY indicator still flashes, or if
the cause of the problem cannot be
found even after checking all the
above items, consult your dealer.
Dec 20, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Nov 24, 2010 | Sansui RZ-8150AV Receiver
How do i switch the Hz setting on the monitor
Usually, if there is a selector switch to match electrical requirements of a monitor or computer to that which may be available in the home, it is for voltage or voltage AND frequency. Seldom is there are selector for frequency only (I've yet to see one anyway).
The selector switch it typically found near where the AC mains power cord enters the enclosure. This can be on the monitor itself - or in the case of a monitor that uses a low voltage cable and connector connected to a power adapter, it would be located on the power adapter instead. Sometimes, these devices automatically detect and switch to match the power being supplied to it. The device should clearly indicate that it will work a wide range of voltages - do not assume it will if it does not specifically indicate that it will.
The selector above is set to 230 volts.
Set the selector switch BEFORE connecting to the power outlet. Most times, the selector switch has the voltage indicated on the slide. The switch will allow the user to choose 110-120 or 220-240 volts. The 110/120 selection is likely to be the 60 Hz variety and the 220/240 selection is likely to be 50 Hz.
If you are unable to locate such a switch, the device is not intended to be changed by the user - and there is likely no "easy way" for the user to change it.
Please rate this reply - good luck!
Aug 31, 2010 | Computers & Internet
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
Speaker compatibility ( Just got this new reciever with 120 volts power requirement of the receiver, but in the philippines voltage standard supply is 220. can i use 110 voltage supply instead? and I dnt...
The most likely answer is no. Unless the power transformer is of the multi tap type and has a voltage selector window on the back panel... Most speakers today have an impedance of 8 ohms. The impedance is all you need to worry about when matching speakers. You can fit 8 ohm speakers to a 4 ohm system, but you cannot fit 4 ohm speakers to an 8 ohm system. It would overload your oputput stages and cause them to fail. It's best to match 4 ohm with 4 ohm, 8 ohm with 8 ohms.etc.
Mar 19, 2010 | Audio Players & Recorders
Gearshift selector problem
The gear selector switch is either out of adjustment or it is bad. Loosen the two bolts holding the gear selector in place and turn it slightly to see if the display stops flashing. You will have to manually shift the transmission lever at the switch into neutral, and then turn the switch until the display says neutral. Tighten the bolts and then check all gears. It's also possible the shift cable could also be out of adjustment. Does the display change if you simply wiggle the gear selector lever?
Oct 22, 2009 | 1988 Oldsmobile Toronado
Receiver Overload error message
Disconnect all speaker wires at the receiver, then turn it on and up. If it stays on, check your speaker wires one by one, then check your speakers one by one. If it still cuts out with nothing attatched, it needs serviced or replaced.
Aug 30, 2009 | RCA RT2660R Receiver
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
JVC RX-7000V Receiver Logo
406 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
