Question about Video Game Consoles & Games
How do i hook a ps2 to a tv that dosent hav rca inputs
    Master:
  • 788 Answers
You will need a modulator box. Available from most electronics retailers for around $20. Check Best Buy, Radio Shack, Walmart, etc...
Posted on Sep 11, 2008
How to hook up ps2 to a emerson tv
Hi Bonnie, first, we need to know if your TV is compatible for the connections from the Playstation. The way to tell, is do you have the matching RCA inputs on the TV? These are the Yellow(Y) Red(R) and White(W) cords that come with all PS1's 2's and 3's. (Yes, all years and models are exactly the same) If your TV does NOT have the matching RCA inputs, don't worry! You can still hook it up to the TV, but it will require another piece of equipment. You will need to add a signal converter box(I will put in a link for it) What this does, is lets you plug the cords from the Playstation, into the box, then out too the place where you plug your cable or TV antenna. These boxes are also called RF Modulators. They are available at every local Walmart or Meijers respectively.I hope this helps. Good luck. ^^
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
Jan 18, 2016 | Sony PlayStation 2 (PS2) Console
I can't hook up my PS2 to my Hisense TV . My PS2 does not take RCA jack and when I tried my RF Adapter it doesn't come on the TV . The TV has digital cable and HD cables . Can some one tell me where m
Ok, Hope this helps. Did you try all your input options? Not just channel 3. The TV remote and TV panel would allow for access to all the input channels.. The manual should be available from the manufactures website or the TV it' self may have a input indentifier located in thespot to where you've connected the PS2.
Good luck..
Nov 06, 2012 | Televison & Video
We had our ps2 hooked up to an old rca tv and was using the satelite remote for it channel had to be on 00 for the ps2 to work. We got a new tv and hav moved the rca and ps2 to another place but don't...
New tv's don't use dead channels like 00 anymore for there inputs.. They use sources to change from different inputs.. Make sure you have your ps2 hooked up into input plugs on the tv and then turn it on the ps2 then look on the new controller for the tv & find a button saying source .. Press that until you see your ps2 on the screen. If not check your connections try again.
Feb 03, 2012 | RCA Televison & Video
How do i hook it up to my ps2?
Your Ps2 should have a connecting lead that terminates in either a SCART plug or a set of 3 phono (RCA) plugs. The TV will have SCART inputs, and also will have Phono (RCA) inputs. So you connect to whichever is applicable and then turn the TV to the correct input. Usually this is done by using a button marked 'AV' or 'Input'
Jul 27, 2010 | Televison & Video
I have connected my PS2 to my TV using the Red, White, and Yellow cables but when I hit the source button the screen just says "no signal". I know that the PS2 is working because I have recently used it...
It is possible that the RCA cable is no good. The yellow = video, the red and white = audio. The input on the TV may be bad, try switching from one input on the TV to another if you have one available. Even if you don't have a free one, remove a DVD player or something else that may be hooked up and try to hook up the Playstation to that input using those RCA wires. This way you can eliminate the port and the wire being bad at the same time. If all else fails and the PS2 works on other TVs, the only option left would be a problem with the TV you are trying to hook it up to. I have that problem on one TV I own, one of the RCA inputs (input 4) is no good. I hope this helps.
Oct 26, 2009 | Samsung LN22A330 22 in. LCD TV
I have a Sanyo TV from approximately 2001-2002. And I'm trying to connect rca cables so that I can hook up my old PS2 with an input box [I think it's called.] but there's no rca connections in the back....
Ok if you want to hook up RCA cables to that TV and dont have a adapter you can buy a RF MODULATOR ( Wall-mart / radio shack for $20.00) and use that to conect to TV and the ps2 will connect to that ( this will also let you use a DVD player with the TV!)
Instructions in RF package!
PLEASE RATE THIS RESPONSE AND HELP KEEP THIS SITE FREE!
THANK YOU!
Jan 18, 2009 | Televison & Video
Polaroid LCD 1700 Playstation One games issue
um sometimes u cannot hook s video n rca jacks at same time do not ask why try just using one or other
Dec 02, 2008 | Polaroid LCD-1700 17 in. Television
Hooking up a ps2 to my monitor.
ok " your tv monitor has a remote, look on the remote and push the input button .
also make sure video cable for ps2 is pluged in to the tv video
input plug, female RCA plug should be yellow
Jan 21, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Wont work!
i can be that ur playstation wire is not gud....
Sep 29, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
