Question about Olympus Camedia C-360 / X-350 Digital Camera
Can't take picture!!
During my job I took picutures and closed the window and after 1 minutes later, I try to open the window again, the lens doesn't come off and I can't take picuture. I used this camera for about 3 years, there's no problems before. I checked batteries but it was fine. I checked quick view, it's fine and I can see whole details that I took. Only and main problem is I cannot take picuture. I tried everything but they won't work. What should I do? I bought this camera in Japan and right now lives in New Zealand. Do I have to send it to Japan to be fixed or it's still possible to be fixed in here?
    President:
  • 3,130 Answers
It will say in your manual where to call or send you camera for repair. If you dont have a manual theres one here . You can read or print it free simply by clicking on the model # at the top of your post and scroll down Good Luck
Posted on Apr 23, 2006
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
One day i took it out of my pocket and it worked fine then later that day i took it out of my pocket and it said Turn the power off and on again and the lens opened then i turned it off and the lens stayed...
Look at my post for a very similar problem. I tried all the steps, pushed and pulled on the telescopic lens thing. Got to the step of hitting it against my palm while turned off, and when I powered it up it worked again.
Jun 11, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Working alone,Maria can complete a task in 100 minutes.Ann can complete the same job in 2 hours.They work together for 30 minutes when Liu,the new employee,joins and begin helping.They finish the job 20...
Check my work, before you hand it in -- there could be some DELIBERATE errors in my fractions. :-)
Marie takes 100 minutes for 1 job.
Marie took 50 minutes for 1/2 job.
Ann takes 120 minutes for 1 job.
Ann took 30 minutes and did 1/4 job.
Ann took 20 more minutes and did 1/6 job.
Together Marie & Ann did 1/2 plus 1/4 plus 1/6 job in 50 minutes.
Together Marie & Ann did 6/12 plus 3/12 plus 2/12 job in 50 minutes.
Together Marie & Ann did 11/12 job in 50 minutes.
Liu did the rest (1-(1/2+1/4+1/6)) job in 20 minutes.
Liu did the rest (1-(4+3+2)/12) job in 20 minutes.
Liu did the rest (1-9/12) in 20 minutes.
Liu did the rest (1/4) in 20 minutes.
Liu worked for 5 minutes.
Sep 17, 2010 | Computers & Internet
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
My Panasonic DMC-TZ3 lost the ability to open the automatic lens cover and therefore no pictures can be taken. I took one picture and a few minutes later I wanted to take another and realized the problem....
Sometimes if you strike the camera, while powered, and against the palm of your other hand, it will open, and may operate correctly for sometime before maybe having to do it again.
This is a very common design problem with the TZ3. I would be sure to get it to a panasonic repair shop before warranty runs out. If it has run out, I would preasure panasonic to fix THEIR design problem for free. Especially if it began to occur during your warranty.
Mar 19, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
repat problem Quiestion as I ststed before look in your instruction manual where to send it . Dont have an instruction manual?? Get one here for free!!
Apr 22, 2006 | Olympus MJU 300 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Olympus Camedia C-360 / X-350 Digital Camera Logo
44 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
