Question about Microsoft Windows XP Professional for PC
Xp blue screen
I have windows xp pro my computer will boot start widows then go to the stop error screen and keep doing it i cant start in safe mode or anything it keeps going back and forth
Dear user, i understand your problem after opening your computer press f1 key reapedly then you ''l get system setup still nothing happens install windows again which you can get in my products
Posted on Sep 11, 2008
  • 94 Answers
Only solution to this is re-install the operating system...
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Aug 17, 2012 | Dell Computers & Internet
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
Sir my windows xp sp2 is not booting and shows stop 0x0000000e meassage with blue screen
You will need to boot it with the XP CD and perform a repair install if you have important data you need to recover. If boot with CD format it abd do a full reinstall. If you have any problems while doing this i would check the memory in the computer maybe by just checking 1 stick of ram at a time. Cheers from Scott and plz vote
Nov 02, 2010 | Microsoft Windows XP Professional With...
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
Blue screen of death. unable to download drivers. can not get to safe mode. cannot reload orperating system disks.
First off, note down all relevant information when you see a BSOD flash across the screen. This includes the error number and friendly name from the 'bugcheck' section of the stop error (see above), and any file names specified in the 'driver information' section.
If the BSOD comes up on the screen for a split-second before the PC restarts and wipes all the useful information away, we need to change some settings within WinXP. In most cases, it should be possible to stop your PC from automatically restarting when it develops a major error, allowing you enough time to jot down the BSOD error message. If you are using WindowsXP, right click on my computer > Properties > Select the 'Advanced' tab > and under 'startup and recovery' click the 'settings' button. This will open a new window, and under the 'System Failure' heading, uncheck 'Automatically restart.' Continuing on, attempt to restart the computer normally into Windows. If the BSOD occurred while booting Windows, you may be taken to a troubleshooting menu and will have to select 'attempt to start Windows normally.' If your computer starts correctly, continue using it and store the error information for later reference. If the BSOD reoccurs at random or irregular periods, see Section D below on troubleshooting intermittent stop errors.
If your system does not start correctly or the stop message happens again, reboot the system. When the POST (memory checking) screen comes up, press F8 repeatedly. This will bring you to the Windows advanced options menu.
In the Windows advanced options menu choose 'safe mode' to attempt to boot into Windows Safe mode. Safe mode loads Windows XP with a minimal set of drivers and no automatically loaded software. If faulty software or drivers are causing your BSOD problem, safe mode should load correctly. If safe mode loads correctly, refer to Section A below on 'troubleshooting software stop messages.'
If safe mode does not load correctly, and/or you get the same stop message upon attempting safe mode, it's time to try the 'restore last known good configuration' option in the advanced options menu.
Restart your computer, pressing 'F8' again to load the advanced options menu and select 'last known good configuration (your most recent settings that worked).' This uses Windows XP's built in system restore utility to restore the most recent save point, which should be the last time you installed any drivers or other software. If your system boots normally after this operation, hopefully your problem has been fixed.
If you are still receiving a Blue Screen Of Death after the above procedures, or if system restore was disabled on your system, note down any new information on the error and start thinking. Did you install any new hardware or software just before this problem occurred? The driver information section of the BSOD may help with this.
If you did install new hardware or software, and you think you know what it might be that is causing the problem, this gives you a big boost in resolving the situation.
Otherwise, proceed to the advanced troubleshooting sections below. Chances are your error is hardware or system file based and will require more effort to repair.
Specific Repair Instructions
If you have a reoccurring Blue Screen Of Death or crashing problem, and can't use Windows effectively because of it, it's time to look at more specific methods of troubleshooting your problem. Depending on the results of the basic troubleshooting steps above, you should have a good idea of whether the problem that is causing the stop messages is related to software or drivers you have installed, or is a hardware or system file issue.
Essentially, if you can't boot into Windows XP safe mode because of crashes or Blue Screens Of Death, you likely either have a hardware error or one or more essential system files is corrupted or missing. If you can boot into Windows XP safe mode, but get constant or frequent BSOD's when running XP normally, you have a software or device driver problem.
Make sure that if you added any RAM to your computer which is a common cause for BSOD that you added the correct RAM for your computer and that it is equally distributed in the ports meaning each port for the RAM has the equal amount of RAM on each side (eg, one stick 1GB, and the other has 1GB, etc).
Jan 03, 2010 | Dell Dimension 2400 PC Desktop
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
Windows xp logo will start to load then......
To solve this will require more information from you. The Blue screen is Windows way of telling you that it has a driver issue with a basic component, usually your video card. Did you recently make any hardware changes? If so please let me know what was changed.
When windows first boots, you can repeatedly press the F8 key until you see a menu giving you choices of windows booting. You need to select Safe Mode. Safe mode should allow you to at least boot without a blue screen. The blue screen could also be cause by a virus or other software.
Microsoft has a description of Safe mode here;
http://support.microsoft.com/kb/315222
but here is a quick snippet
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Dec 13, 2008 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Blue Screen error
Try to boot the PC without the XP Home CD in the CD drive, and keep pressing the F8 key until it comes up with a boot menu that includes a Safe Mode option.
If you had the XP Pro CD I'd suggest doing a recovery, but XP Home doesn't have that option I don't think.
You may have to try a few times until the boot menu appears. Don't hold the F8 key down - keep pressing it!
When you get into Safe Mode, right click on My Computer and choose Properties. Then go to Hardware tab (i think - not in winXP right now) and choose device manager. Just remove the Video Card from the list altogether, and then restart. Should force it to use generic video card drivers.
then check your video card model and look for the updated driver
Nov 17, 2008 | Dell OptiPlex GX150 SF PC Desktop
Blue Screen
Ok you have an issue, the error code you have is a registry errorthe best way to fix this is to boot from your windows cd rom and do a repair. If you dont have a windows cd then you can try going into windows in safe mode. turn the computer on, keep pressing the F8 key at the top of your keyboard. after it goes through the boot sequence it will take you to a window with a few options right at the top will be safe mode. If you have windows restore running it will prompt when you first go into windows, choose the option to do a restore, it will then restore to the last time a system change was made. that should fix the problem, if it doesnt then ask me and I will get you through this with the minimum of fuss and make sure you dont loose your data
Aug 24, 2008 | Toshiba Computers & Internet
Microsoft Windows XP Professional for PC Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
