Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Can someone please tell me what code dL means on a whirklpool duet washer?
  • 5 more comments
  • sphalp Oct 15, 2008
    My duet says error code dl then f
  • Anonymous Nov 22, 2008
    Tried the turn off and unplug for 10 minutes twice. Same, dl and F. Checked the breakerbox too and reset just incase.
  • Anonymous Dec 29, 2008
    tried the solution above, i can then start the washer but after a few minutes the dl code comes back,i unplug and the the 10 minute thing and am able to start washer in rinse mode only..after a few minutes the code flashes again, sometimes when i replug in i am unable to open the door, it;s still locked., what does the code mean, how can i fix it..yeah the warranty just ran out. the model is ghw9150 pwo. Help me please!! can't afford a repair man.
  • bobbbad May 11, 2010
    Harvey,
    Is their an 'instant' method for this repair? I am currently dealing with the issue repeatedly and it is becoming very annoying. I have not consistently applied the 10 minute rule but believe it has worked for me by accident.
    This last time I opened the top and examined the control module. I may have found an instant reset by pulling and replacing the right blue wired plug (a set of three plugs are on the right side of the control module).
    Is this a safe operation or should I accept the 10 minute rule and work that solution? I am interested in your call on this.
    Thanks for the advise above
  • Anonymous Mar 17, 2014
    whirlpool duet washer error code E01
  • Anonymous Mar 22, 2014
    get 3 short buzzes and then error codes E-2 then F-5
  • Anonymous Mar 23, 2014
    CODE F5 APEAR ON THE SCREEN
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
538 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
