Black lines on the back of the printer page
I have a lexmark x7170. When I print ,the underside has light black lines. I know I have to clean something, I just don't know what? Thank you
  • 1,879 Answers
The rollers / guides the the underside of the paper touches
Posted on Sep 11, 2008
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My lexmark X7170 Printer Skip line when printing how do fix it
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 03, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
  2. Go to Programs.
Hey, I have the X7170 printer and haven't used it for about a year. Now, the fax, and scan works fine, but when I print a paper, it comes out blank even if the ink catridge is full. Seems that there is...
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Jun 24, 2011 | Lexmark X7170 All-In-One InkJet Printer
This has been addressed a lot but my problem isn't solved. I have a brand new Black 32 toner for a Lexmark x7170 all in one printer. It won't accept the toner - gives me the message "left...
It could be a faulty cartridge. Have you already tried inserting a different known working cartridge? If error continues to pop-up even with a different new or a known working cartridge, then it could be a hardware problem. Try to contact Lexmark technical support on the phone for additional assistance.
May 10, 2011 | Lexmark X7170 All-In-One InkJet Printer
My lexmark X7170 keeps printing black pages instead of what I am trying to copy. It used to be black stripes but now is completely black.
Do you get the same result/image when scanning to your computer? Remove the cartridges from your computer. Then close the printer cover.Unplug the power adapter from the printer.
Wait at least 10 seconds before replugging the adapter into the printer. This will give enough time for the printer to reset. When the printer turns on, reinsert the cartridges. Try to make a copy or scan again. If you're still getting the same result, I would strongly suggest you to contact Lexmark technical support for additional assistance.
May 09, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
After refilling my black cartridge, my lexmark X7170 AIO (on printer copy setting) prints out a blank page even after printing an alignment page showing black bars & blue dashes (no other colors?) I...
Try to print some more pages. The ink will take time to go down as it is not free flowing. This is due to the air beetween the new ink and the old ink, after some printing the air is push out and then you can have a clear print.
Sep 11, 2010 | Lexmark Office Equipment & Supplies
Prints all black page when faxing printing or copying
www.samsung.com/.../printers.../black...printers/.../index.idx?pagetype... - United States -
Aug 02, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
107 people viewed this question
jasbo
jasbo
