Flashes protect Flashes "protect" flashes protect
  • geesparx Jan 23, 2009
    flashes protect when switched on
  • itsbeach May 03, 2009
    This is very frustrating! The unit is less than 6 months old. When you turn it on, it starts up, but then says "Protect" and shuts off. There's nothing you can do. There is a disc stuck in the tray as well. It won't eject.
My system flashes protect then switches off.
Posted on Jan 11, 2009
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Red light, turn on, goes green, flashes yellow then flashes green
connection problems or power surge connect to surge protecter
May 01, 2010 | Sony Playstation 3 (PS3) Console
No sound no protection light
u must have a faulty wire...recheck youre instalments....or get a professional to do it for you..
Feb 19, 2010 | Kicker ZX10001 Car Audio Amplifier
Protect flashes. I reset as manual instructed. I
Don't forget to disconnect your sources also(dvd,satellite,vcr,cd player,etc) they could have a short in any of them causing receiver to go into protect,If still flashing "protect" your Sony could have an internal short of it's own, or caused by an external short previously mentioned. Good luck !
Nov 27, 2009 | Sony STR-DE695 Receiver
All it says is protect and nothing works what do i do
the protect message flashes on my KDC MP342U radio. I have unhooked each speakers one at a time and reset the radio but the protect still flashes
Nov 19, 2009 | Kenwood KDC-MP342U Car CD Player
Screen flashes protection; can't record
check the protection tab on the memory card of your camcorder. move the protection tab to no.
Jun 27, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Kenwood excelon cd player flashes protect
check your wiring the unit is doing the right thing by by shutting down or your check you skpr terminal
Jun 25, 2009 | Car Audio & Video
KDC-MP443U - flashes protect
I had the same Prob on my KDC 237. I hit the small reset Button on the front and it fixed it. Hope this helps.
Mar 03, 2009 | Kenwood KDC-135 CD Player
How to remove write protection from sandisk cruzer flash drive
how do I remove write protection on my cruzer 2GB thumb drive
Feb 21, 2009 | Cameras
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
674 people viewed this question
 Grubhead
Grubhead
