From the main menu i cannot find the button to change the ring tone and the wall paper
I have the z10
Go onto the Control panel and down to home settings,
it wil go onto the plug in tab, click right and it will come up with your current wallpaper
to change ring tone edit your profile on the control pannel (on the options button) Hope this has helped xxx
Posted on Feb 03, 2009
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
How do i change my text tone on my Blackberry Curve?
on the main menu click on profiles (speaker icon) then scroll down to advanced. Click on the profile you use and scroll down to SMS. In this menu you can change then ring tone when you get a text message
Jul 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
How to change ring tone? Lost manual.
usually this is done one of two ways
if the phone has a menu button
press it once then use the arrow keys until you see "ring" or "ring tone" in the display
then use the arrow keys again and you should hear different ring tones. when you find the one you like press the menu button to lock it in
if the phone has a program button and no menu button
keep pressing the program button until you see "ring tone" in the display.then use the arrow keys until you hear the ring tone you like. then press the program button several times until you exit the programming mode.
you can follow the above steps to set the ringer volume also
Jul 16, 2009 | Uniden Cordless Phone
Just got this used phone for school.how to change the ringtone It's a very annoying one now.
Jul 15, 2009 | Uniden Cordless Phone
Change ring tone
Here's how to choose your phone's tones, alerts, vibration etc: 1. On the main standby screen, press the white menu button.
2. Select "Settings".
3. Select "Personal".
4. Select "Profiles".
5. Double-click on the profile you normally use (this will usually be "General").
6. Select "Personalise".
7. Click on whatever you want to alter (for example "Ringing Tone" to change the call ringtone). Note that there are different ringtones for ordinary and video calls, and different settings for keypads and touchscreens.
8. When you've finished altering the settings, press the red button to go back to the main standby screen.
To switch to a different profile, tap the standby screen's date and choose the profile you want.
How to choose a ringtone from the music player You can also select a ringtone from the 5800's music player, just go to the track you want to use and select "Options". One of the options will be "Use Tone", giving you the choice of using it as the ringtone for the current profile, or as the tone for a specific person.
Jun 24, 2009 | Nokia 5800 XpressMusic Smartphone
CHANGE SMS TONES ON BLACKBERRY FLIP 8220
On the menu screen, you go to the speaker icon (Profiles) and click on it. From there you will click on Advanced. It should have your current ring selection highlighted already. You will then click the menu button click on Show Ringtones and choose the ring tone you want to use. Hope this helps!
Jun 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
How to change ring tone for normal profile with a mp3 ?
ok I resolved by myself. I copied the mp3 to the memory card. Then from Main Menu: My files->Music->Memory card->Music->Options->Set as->Ring tone. This is a great phone. I'm loving it !
Oct 13, 2008 | Samsung J700 Cellular Phone
Ring style not working
just go to the tone u want to select n then press options n then use tone n then use as message tone
Apr 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
