Most GPS problems - Hangs, frozen screens, problems
acquiring satellites, ETC, can be attributed to the device not having the latest
firmware installed.
This firmware enables it to communicate with the
satellites - but if they aren't speaking the same language they get confused
easily.
For Garmin GPS Automotive units, Garmin has you do
the following before sending it in for repairs:
1 - SOFT RESET
2 - HARD
RESET (
CLICK
HERE to see instructions for either reset)
3 - UPDATE the device using
their WebUpdater software (
CLICK HERE for
that)
Garmin is the only company that offers repairs
AFTER the warranty has expired. They offer a
FLAT RATE REPAIR
service for units no longer in warranty.
For Other GPS units please consult your owner's
manual or their support site - as each model - and even manufacture dates - can
lead to different reset procedures.
TomTom
NAVIGONMAGELLAN
NEXTAR does NOT offer any types of Firmware or map
upgrades or repair services. Instead - they have an exchange program to update
to a new UNIT for around the same price as a repair would be.
CLICK HERE for
more on that.
WARRANTY on most GPS devices is 1 year from the
date of purchase.
Broken screens are considered ABUSE - and not
covered under warranty.
Finally - If your unit is on the charger for HOURS,
You've tried both the car AND USB type charger, and you turn it on... it stays
on for a minute (or so) then powers down or never comes on at all - the battery
has lost it's ability to hold a charge and must be replaced.
Looking around YouTube - you can get a tutorial on
how to CAREFULLY crack open just about any GPS. The tool(s) necessary typically
are included with the battery purchase. Typically batteries run about $25
NiCd batteries are meant to be energized once a
month so they keep active, and don't build up deposits that lead to their
premature failure.
I hope this was helpful for you.
Thanks for using FixYa - a 4 THUMBS rating is
appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Sounds exactly the same and I don't know where to go from here.
Same machine / model: The antenna reading shows 'good' but 'no update' shows and it doesn't seem able to pick up any sats / position etc. The manual said that it might be a flat back-up battery - changed that but same thing. Flashing red light.
The only option left is that the time and position are wrong...but I can't get past the 'offset' setting to adjust the time & date. Any ideas on this specifically?
check GPS antenna i have a small crack in my antenna
exactly the same problem
on 20/05/2009
(shut down oktober 2008)
