Question about Emerson AV101 System
Display but no sound
I have an Emerson AV101C system that is responding to the different commands as shown on the display panel, except that the CD/DVD drawer won't open and no sound is coming out from the speakers even in AM/FM receiving mode. Is that a common problem, I'm suspecting a short circuit somewhere but where should I start from? I'm a retired technician but all I have on hand is a multimeter since I was using my employer's equipment when I was working. Thanks
    Novelist:
  • 130 Answers
Some stereo units have a function on them for an equalizer. What it does is when its in a certin mode you can turn on tape2 and it will send the signal threw the tape2 and if an eq is hooked to it you can alter the sound. Now here is the problem, if there is nothing hooked to the tape2 (not sure what yours maybe called if nothing is connected you dont hear anything because there is nothing to complete the circuit. Im not sure if your unit is like this but it could have somthing similar and its in that mode.
Posted on Apr 23, 2006
    President:
  • 3,130 Answers
Your gonna need a service manual and then you should check the power supply first and then the microprocessor curcuit.Good Luck
SOURCE:
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
Jul 22, 2016 | Computers & Internet
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
My tv is an Emerson 20" HDTV. Last week the closed caption just popped on and we can't get it off. My cable company, Comcast, said my box is not equiped to support closed caption so it is the tv....
I think Comcast doesn't know much about their equipment; their box has no influence on CC since it is embedded in the program material and is passed through their receiver to your set. There are two possibilities; the remote is no longer sending the pulse train to control CC or the set's receiver isn't responding to that command.
You can do a rough check on your remote if you own any kind of digital camera; still or video. Turn on the camera so that you have a display picture of the room you are in. Point the remote toward the camera's lens and push (and hold) a button on the remote that you know is working, such as the "Power" button while looking at the LCD display of the camera. You should be able to easily see the blinking of the InfraRed LED(s) which most all digital cameras can 'see.' Once you know what to look for, try the button that should control the Closed Caption function. If you don't see anything on your camera LCD display, that button (or the circuit it controls) isn't sending out the code train required to control that function. If that is the case, you may be able to buy an original ('universal' remotes really aren't) replacement remote from:
Remotes.com
Conversely, if you DO see the remote blinking, then the circuit in the TV set that responds to the CC (and others) command has partly failed and that is more costly to repair.
May 08, 2011 | Emerson CR202EM9 TV
I have a jvc kd-s590 in my car & have no idea how to set the clock. It'd driving me crazy. Please help!
1 Press and hold SEL (Select) for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Set the hour. 1 Select "CLOCK H" if not shown on the display. 2 Adjust the hour. 3 Set the minute. 1 Select "CLOCK M." 2 Adjust the minute. 4 Press SEL (select) to finish the setting. 1 2 During tuner operation: During CD operation: Frequency Clock To check the current clock time (changing the display mode) Press DISP repeatedly. Each time you press the button, the display mode changes as follows. To Cancel Advanced SCM You can cancel the Advanced SCM (Sound Control Memory), and unlink the sound modes and the playback sources. When shipped from the factory, a different sound mode can be stored in memory for each source so that you can change the sound modes simply by changing the sources. LINK ON: Advanced SCM (different SCM for different sources) LINK OFF: Conventional SCM (one SCM for all sources) 1 Press and hold SEL for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Select "SCM LINK" if not shown on the display. 3 Select the desire mode - "LINK ON" or "LINK OFF". 4 Press SEL (select) to finish the setting. • If the unit is not in use when you press DISP, the power turns on, the clock time is shown for 5 seconds, then the power turns off. 1 2
Nov 03, 2010 | JVC KD-S590 CD Player
What are 3 functions of syntax in command 'dir'
The syntax is the correct method of typing a command. The command must be entered in the correct order and spelling for the operating system to accept it. So : dir/w is correct But dir \w Is not..
dir/w will display the contents of the current directory, but in a wide format dir/p will display the contents of the current directory until your screen is full. You then press any key to scroll down the directory listing until you reach the end. dir will display the contents of the current directory with each directory item shown on a new line. you can use each of these switches together too.
dir/w/p will display the contents of the current directory in a wide format but the listing will pause when the screen is full. Pressing any key will scroll the listing down. A word to the wise. If you are not comfortable or have little or no experience with working in the DOS Command environment, DONT.... You can cause serious damage to a system simply by mistyping a command or using the wrong command. Do so at your own risk..
Feb 05, 2010 | Gateway GT5220 PC Desktop
I WANT TO CHANGE MY SONY TV IN THE SERVICE MODE FROM PAL I TO BG. WHAT DO I DO?
    The method you are talking about is present in MAIN MANU . PAL,NTSC etc are video singnals system and BG,DK,I etc are audio signals system and both are in manu of the set.
     As far as concern you require the method of entring service mode. It is given below :
ENTERING SERVICE MODE:
In standby mode, press buttons on the remote commander sequentially in rapid succession as shown below:
DISPLAY---> CHANNEL 5----> VOL (-)--->POWER
Note that this differs from entering the service mode (volume [+]).
Thanks for using fixya.
May 13, 2009 | JVC GM-V42 42 in. Plasma Television
Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Oct 05, 2008 | Bose Lifestyle V20 System - black Theater...
Problem keying in commands on Emerson MW8102SS
It sounds like you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Sony STR-VX550 receiver does not respond correctly to commands from optional Sony RM-S750 remote commander. Remote is working properly and activats all functions on my other STR-VX550. Only on/off command...
If this is a recent occurrence, unplug receiver for 20 minutes. This will reset the receiver. If the remote is programmable, reprogram it for the receiver. If you do these steps and it does not work, you need a different remote.
Aug 22, 2008 | Sony Audio Players & Recorders
Doesn't respond to any commands
condensation has formed wait for 1 to 2 hours to evaporate.
the unit can not play discs other than who listed in operation instruction.
Aug 18, 2007 | Panasonic SC-HT820V System
70 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
