Question about Motorola Mobility RAZR V3
My camara phone
When i try to take a picture o a video it just stays all white and i try to take the baterry and cleane it and i used the master erase but it's still the same, it was working fine when suddenly it start doing thta what should i do?
    Brigadier General:
  • 7,752 Answers
The phone needs either a flash of firmware or the flexcable need to be replaced so take it to a mobile service center and have them fix it for you.
Posted on Sep 24, 2008
When i going to use camara display "Error camara not available" restart phone and tried so many times but not resolve please help me what can i do...
I also used to have an xperia u and it also produced the same problem. First i tried to simply reinstall the whole operation system on it, this you can do through the sony update service software via your pc. If this does not help, (and this helped me only once) next time i simply took apart the phone, and tried to clean it checked the contacts within it (all the copper parts). After putting the device back together, my camera was working again. For the taking apart process you will need special tiny screw drivers.
Mar 05, 2014 | Sony Xperia U ST25I Android OS v2.3...
How to reformat the phone?
formatting your phone will set back your mobile to its original setting.
to be able to do this,just go to settings > initial set-up > master reset
* If you choose master reset - this will just reset your setting to default.
* if you choose master clear - this will erase all content of your mobile including your contacts,messages etc. be sure to back up your files first before doing this method.
* if ask for the code
default unlock code is - 1234
default security code - 00000000
good luck.
Jun 18, 2011 | Motorola Mobility RAZR V3i Cellular Phone
What codes to format my nokia 6300
NOTE: Performing a Master Reset on any Cell phone will Master reset your cell phone and erase the phone completely including contacts, pictures, videos etc.
To perform a master reset on your Nokia 6300 or 6301 you will need to:
on your Nokia 6300, 6301 dial *#7780# eneter your security code (default is 12345)
NOTE: Performing a Master/Hard Reset on any Cell phone will Factory reset/clear your phone and erase the phone completely including contacts, pictures, videos etc.
Jun 17, 2011 | Computers & Internet
My poloroid camara wont hold a charge even when i try to put new baterries in it have have tried all kids of batteries and nothing
Take a cotton swab "dampened" in rubbing alcohol and clean the contacts for the battery/batteries inside the compartment. Thank you, Dana
Feb 15, 2010 | Polaroid i835 Digital Camera
The Camara keeps saying: Remove Memory Card and clean
You continue to get a message to remove your memory card and clean with a soft cloth. If your camera does not make you open the battery compartment to remove the memory card I would open the battery door and take the batteries out. If not clean the memory card contacts with a white pencil eraser. Please be sure it is a white eraser only. The other colors of erasers are made up of different materials and do not work as well or at all. One other option if you are having trouble finding a white pencil eraser, you can use a little rubbing alcohol and a q-tip, just be careful not to soak the whole card and to let it fully dry before you use the card again. This should take care of it.
Jun 08, 2009 | Olympus Stylus 790 SW / µ[mju:]790SW...
Scratched Finish on Screen While Cleaning
Here are some solutions to consider. Try in an inconspicuous place first.
1) Use a clean WHITE pencil eraser. Yes WHITE pencil eraser. Some people use a pink eraser and then a white eraser over that for faster removal. Wipe residue off with a damp cloth.
2) Use White Petroleum Vaseline Jelly over the stratches. This may have to stay on an hour before wiping off.
3)You may also get commercial LCD scratch removers on the 'net.
An LCD screen should only be cleaned by using a damp(not wet) with water microfine cloth. Never use household cleaners of any kind.
Mar 13, 2009 | Sony Televison & Video
Camara not working
try reset ti factory setings. if not, maybe the camera flex needs tobe replace or the camera itself.
Sep 06, 2008 | Nokia N73 Cellular Phone
Asus a7m266 was watching somthing on a tv tuner and computer died, every time i switch on all i get is a repeditive 1 second long beep, then 1 second pause no bios or display
try taking out the battery on *********** board, then put it back in and try it. this should reset your bios.
also there should be a 2 prong jump block on *********** board to reset bios.
check *********** boards book for location of this pin.you will need a jumper to do this. if you have any old hd's or cd dvd drives laying around you can use one of them. the little black thing for master/slave jumping..or an old mother board.
i have like 4 of them in the bottom of my case just incase i have to reset bios the hard way.
hope this helps.
willowcreekjim
Aug 27, 2008 | ASUS Computers & Internet
Motorala razor camara problems
master reset the phone..
menu/settings/initial setup/master clear/master reset/ security code 000000
Jan 03, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
