Question about Philips Magnavox MRD510/17 Theater System
Lost installation guide for Magnavox MRD 510 Home Theater System
I can't get sound from TV to speakers and when playing a DVD - I get sound, but can't get the picture. I guess I don't have the input right or something. I have lost the guide to install.
  • 10,594 Answers
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Posted on Sep 11, 2008
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Magnavox MRD-510- when I plug it in, it just makes a clicking noise and the power button keeps flashing. When I unplug this unit it continues to click for 5 seconds. Only owned for about 5 months and now...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Nov 30, 2008 | Philips Magnavox MRD510/17 Theater System
No sound on Any Speaker
Magnavox would suggest the following as would I
  • Increase the speaker volume
  • Disconnect the headphones
  • Switch on the selected source or select another source
  • Reconnect the speakers
  • Change and play another disc
  • Swap speaker connections
Oct 12, 2008 | Philips Magnavox MRD20037 System
No sound form my magnavox mrd-200
As long as the colored connections are in the correct holes (red with red and so on) then you should have sound if not then the built in amplifier is shot, it is probably better if you get a new system or contact Magnavox for a exchange price on out of warranty units which they have
Aug 16, 2008 | Philips 0603 magnavox mrd200 System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Power middle speaker
Yes, you must hook the center speaker to a tuner, or it will not work.
Oct 13, 2007 | Philips Magnavox MRD-250 System
Philips Magnavox MRD510/17 Theater System Logo
756 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
