Question about Compaq Presario Notebook
Ram installation i have a laptop compaq and need to add a ram stick, how is this done
    Guru:
  • 160 Answers
Before doing any work ground yourself by touching any metal part of laptop chassis,flip laptop upside down,underneath should be door wih one screw maybe two,if you look close you will see a memory stick icon next to screw.open door, ram removes at an angle pull straight out,to replace push with a little force then press back down,replace door,reboot.
Posted on Sep 11, 2008
Low memory on my compaq presario laptop
You just need to add more Ram Memory, nathancarol7.
What is the Compaq Presario's model number? It's on the Bottom of the laptop in a white Service Tag. P/N = Product Number, and the number I need. Post back in a Comment.
Then I can show you the Ram Memory module/s ('Stick'), it uses, and can guide you in installing.
General example of a SO-DIMM ram memory module, as used in a laptop,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Regards,
joecoolvette
Nov 26, 2012 | Compaq Computers & Internet
Compaq presario m2000 notebook continuously beeps while starting up. The computer is very slow once fully logged in. Do you have any suggestions to fix these problems?
The beeping usually points to a RAM stick failure. If your laptop has two sticks of RAM then one of them has failed, which further explains the slow performance of the laptop once it's fully loaded.
To troubleshoot this issue, you'll need to remove one RAM stick at a time, and see if the laptop boots at all. When you have only one stick of RAM and the laptop does not load after the beep signal, then that installed RAM stick is bad. You may want to try and clean up the contacts with a cotton cloth and some alcohol just to make sure it's not an oxidized contact issue.
If this was informative and helpful please vote with a Thumb Up. Thank you.
Feb 01, 2011 | Compaq Presario M2000 Notebook
Which ram goes where?
Hi, There is no particular order from which you would put your RAM sticks into those slots. however, if the Slots are color coded (2 reds, 2 whites for example), you should put the same sticks in the same color. so make sure those 512mb sticks are both in red and your 1 gb sticks are both in white (colors were just set for example, actual ram slot color may vary). Those color coding were done to use the dual channel pairing of RAM sticks so the same type and speed of RAM sticks should be placed on same colored slots.
Jun 15, 2010 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
Installed New RAM in laptop. Led works but screen is blank.
did you check the type of RAM you are inserting maybe the RAM is not compatible
a ram has many specifications including the frquency at which it works
so check if you got the right ram for the laptop
the frequncy is something like 533, 800 Mhz so see the one you had originally and get the one required for the laptop
Jul 01, 2009 | HP Compaq nx6310 Notebook
I have a compaq pressario 2200 notebook when i try to restart it after instaling things it wont start up all i get is a single beep and a black screen i cant hear the fan kick in and pushing the restet...
One of your RAM sticks might be bad.
Hopefully you have two RAM sticks. They are located behind one of the doors under your laptop.
Try removing one of the RAM sticks & fire the PC up with just one RAM stick installed.
If it still doesn't work, try removing the second RAM stick & replace it with the RAM stick you originally removed. Then try firing it up again.
If that works, try re-installing both sticks again. The contacts may have just been dirty & needed the RAM to be re-seated.
Mar 15, 2009 | HP Compaq Presario 2200 Notebook
Need to add ram
its depend that upon your RAM slots. If RAM slot is two then its means you can add only 2 RAM.
Jan 02, 2009 | HP Compaq Presario V6000T Notebook
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop http://www.dealtime.com/xPF-Compaq-Refurbished-COMPAQ-P4-M-1-8GHZ-256MB-30GB-14-1-TFT-CDRW-W-XP
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
What are the ram limits on a compaq presario 5000a. I put 256 ram in the compaq and it only reads 128. Why?
You can install up to 3 sticks of 512 mb of memory. Did you add a 256 stick to the already-existing 128? You need to put DDR266/PC2100 memory. To troubleshoot, remove the 128 stick and put your 256 in and see if it is recognized. You will know right away from the bios screen. Memory needs to be the same type.
Jul 16, 2008 | Compaq Computers & Internet
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
Compaq Presario Notebook Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
