Question about Fahrenheat PHH15002 Oil Filled Baseboard Heater
Baseboard heaters I need to know what type and size heaters to put in my finished basement.
    Problem Solver:
  • 12 Answers
Measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Posted on Sep 29, 2009
I have a large room in my basement where I would like to install four Marly 58" baseboard heaters to work off one thermostat. The units are rated at 1250 watts each for a total of 5000watts. I plan to...
Using the equation I = P/E where "I" is Amps, "P" is Watts, and "E" is voltage, we find that your 5000w circuit will have an Amperage of 20.83. A 22 amp tstat will work, it will just leave you no room for surges. I would suggest splitting the baseboard and using 2 thermostats. Hope this helps
Aug 10, 2010 | Marley Electric Hydronic Baseboard Heater,...
How do i know what size baseboard heater to use in any given room.
Basically each baseboard should be rated for a particular heat output...Watts...which should have an equivalent to square footage...look in the Specs or askj the Supplier....and that will vary on the Heat loss of each particular room...how big the windows are....how well insulated the room is etc
Oct 16, 2009 | Fahrenheat Electric Convector Baseboard...
I want to install 240v baseboard htrs in a below ground basement.
you must really love your hydro co
those heaters are a huge draw on your bill
why not install radiant heat they are cheep now in compairison
the unit is a central mount run the line in a loop arround basement and conect all the heaters in drop lines off the main line small thermostat valve for each room to control heat
cost is more for unit but savings are greater too they now make a light duty units designed for your porpose
single direct electric heaters are pigs on the hydro bell if you have gas or electric it is cheeper to run a small boiler or heat on demand system
Aug 04, 2009 | Heating & Cooling
WHAT SIZE BREAKER IS NEEDED FOR 240 VOLT ELECTRIC BASEBOARD HEATE
If there is a 15 amp breaker on this circuit now. Then I would assume the the wire to this breaker is only capable of handling that size and NOTHING larger. There are to many variables. You need to know the maximum amp draw rating of the device. The wire size going back to the service entrance (fuse box). You will also need to know the total power draw of the service entrance to determine if the box can handle the total load. Are there any other branches off of this circuit? I suggest that you get advice from an electrician. If you overload the circuit, you may think everything is ok. But you can cause a major problem. I do not think that you want to take the chance of overloading a circuit. This can cause a fire and or death. Have this inspected by a professional. If you insist on doing it yourself.... contact your local building inspector for guidance.
Apr 21, 2009 | Fahrenheat Electric Convector Baseboard...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
240 or 120
240V used 1/2 the power of 120v It shoudl be wired on a dedicated circuit.
Jan 26, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
A buzzing noise
Why do you say put in line to stop the buzzing? What is it that tells you the wire is creating the buzz?
It could be anything from a loose sheet metal part, rivet, fan, transformer, loose connection, or just the way it was built, although a loud buzz sounds like a problem waiting to happen to me.
No there is nothing to put in line to make it quit buzzing, I need to know all the information about the device, voltage, amps, brand, and then tell me how it is wired including number of wires, size of wires, voltage, how it is wired to what colors, how far from breaker, what breaker and size, and anything else that seemed unusual to you during install if anything.
Write me back here or allexperts.com or wbwill@sbcglobal.net.
Oct 24, 2008 | Fahrenheat Electric Convector Baseboard...
Electric baseboard heat stopped working
It sounds like your electric heater coils burned out. Contact your manufacturer on how to replace or repair them.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Heating & Cooling
Fahrenheat PHH15002 Oil Filled Baseboard Heater Logo
148 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
