How to reset the tv timer for the bulb - Televison & Video
  • 435 Answers
This is a quick reference guide to show you how to reset your TV's lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can subsitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
Thanks
Posted on Sep 11, 2008
  • Narmada Anand
    Narmada Anand Sep 11, 2008
    Also, if you give the product name and details then it would be easier for me to help..........The above mentioned is for Samsung brand.
    Thanks
    President:
  • 1,450 Answers
What brand and model tv?
  • TripleTauto
    TripleTauto Sep 11, 2008
    Turn your television on
    Press volume down on the TV
    Press the mute button on the remote
    Green LED light on power button will flash
    -timer now reset
    try this for a panasonic
  • TripleTauto
    TripleTauto Sep 12, 2008
    did you ever fix this?
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
Have replaced projector bulb,can not reset lamptimer
turn the tv ON: On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
Oct 22, 2009 | Vivitek Televison & Video
I had the bulb blow out in my Sony 60" projection TV. I replaced the bulb and with in 2 weeks I had the on screen notice appear that the bulb was failing. I returned that bulb for another one but the on...
Have you reseted the lamp timer of your tv? if not, you should do it, because it's just adding more and more hours to it to the ones it already had and it's indicating the tv that the lamp is going out, reset the lamp timer and you should be fine, if not, it's probable you might have a defective ballast which are not expensive, they're way cheaper than a lamp, they're running around 70 dlls
Jun 29, 2009 | Televison & Video
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Dec 28, 2007 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
