Question about Panasonic PT-47WX49 47" Rear Projection Television
Wavy colored lines of captioning at all times, can't turn off
My tv has wavy colored lines of closed captioning that can't be turned off. It also has a huge black square in the middle of the screen that can only be turned off by pushing in the action button, but that brings up the scrolling bar of the menu. Any ideas?
  • lovelace123 Sep 11, 2008
    Unplugging the set for 20 minutes did no good. Any other ideas?
    Master:
  • 726 Answers
Did you touch any settings try settings if the tv is on auto not pal or nts
the wavey lines could also mean there is a fault in the tv the best bet is to contact a handy man or a service repairer
Posted on Sep 11, 2008
  • Panasonic Master
  • 19,396 Answers
Try first unplugging the power cord for fifteen or twenty minutes , see if this can reset and fix the problem.
  • Ginko
    Ginko Sep 11, 2008
    More than the lines, the weird thing is the black spot at the center of the screen.
    If the spot was always there, it was just an object in the middle of the light tunnel inside the TV, this is wuite common and not too difficult to fix.
    As the spot is disappearing when you press the menu, that means that it is an electronic problem.
    The lines are probably a faulty IC or another similar problem. For both problems there is no simple solution.
    The only solution is taking apart the TV, inspecting the light device at eyesight, and testing the onboard components.
    The black spot ( unless is a light tunnel problem) won't even be mentioned in the service manual, there is no troubleshooting diagram for it, it means that this will be a difficult job even for a technician.
    Probably the solution is replacing the jungle chip , that is thhe main CPU that controls your TV board, and re flashing the eeprom where the TV firmware is stored.
    Both operations must be done at a panasonic service center.
    Call the phone number at the end of the user manual to contact PANA. If the unit is still under guaranty the job can be done for free.
    If guaranty is expired you should be able to buy an extension that will be less that the repair fee and will cover you for one year or two.
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
TV screen turns totally green and has a wavy line
try remove the casing of ur tv go on the yoke, u see small board connecting to the yoke the try resolder all the part.Look on the main board some part are only lost look for it then resolder.Most especially the of chroma section wherein the colors are blending here i recommend to resloder properly sure to it that it will not jump to other pin.
Jun 18, 2009 | RCA 24F512T 24" TV
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Panasonic rear projection
You should turn the close caption off in the menu this will get ride of that box. If you are seeing double image on the screen that is a different problem though. Let me know what the pic looks like after you turn clsoe caption off.
Tim Nolan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
