Question about Garden
Craftsman rideing mower
When i turn the key to try to start it it just clicks,all my safties r made up new battery and solenoid all the relays r new and i have voltage at the solenoid and comming out of it!
  • Anonymous Apr 07, 2009
    Battery fine, all switches fine, celanoid new... still NO START! hear only a click....
  • Anonymous Mar 28, 2014
    I get a click from the engine when I try to start. I have fitted a new solenoid and the battery is OK
I have same problem. the ingnition switch is bad or dirty.try puting pressure on clip while starting.my works by doing this
Posted on Sep 21, 2008
  • 21 Answers
Try checking the brushes in the starter motor
or putting direct power to the starter
Posted on Sep 14, 2008
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
My craftsman riding mower wont start when i turn the key all i hear is a click ,it has a new starter
Terry,
Sounds as if your battery is drained. Or it also couldbe a the solenoid. You can use a multimeter to test the battery to see if it has the 12v needed to start the engine, also you can use it to test the solenoidto make sure it's relaying the voltage.
If u have a set of jumper cables, u can test by simply hooking them up to another battery source, as in a car battery, and then attach to the mower battery, won't hurt anything..
If you KNOW the starter is good, then it can only be these 2 other things that I have mentioned. Hopefully the starter is not defective...
Oct 08, 2015 | Craftsman Garden
Will not start new starter
Most likely the solenoid. With the key on, touch the two large terminals on the solenoid with a screwdriver. If it tries to start, the solenoid is bad.
Oct 16, 2014 | Garden
What will not let my mower start?
try the brake switch unhook and jump if does replace swtch that how you check the safty check the one under seat leave un jump then try jumped check al like this you will find bad switch 3 to 4 switchs all lawn mowers
Aug 26, 2014 | Garden
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
How do i know if relay is gone on my craftsman ride on mower
If you can access it? check the purple exciter wire to the solenoid with the parking brake set. machine in nuetral and the key switch to the start position, with a 12volt test light see if you have power that wire? if not you probaly have a bad safety switch (brake or nuetral start if gear drive) if you do have power then try to jump accross the 2 main post on the solenoid if it turns over your solenoid is bad if it doesn't then it is a good posiblity it is the starter. Then try to run 12 volts from the positive terminal on the battery directly to the main lug on the starter. I hope this helps!
Aug 21, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding mower-starter relay clicks-no start even with jumpers.
The frame of the tractor is the same thing that starter grounds to,so yes ,put the ground any where on the frame or engine block to test the starter.An easier way to test everything is to cross over the large posts on the solenoid with a screwdriver and if it turns then the starter is not the problem.Then you will need to put power from the post on the solenoid that has the battery positive connected to it ,to the post on the solenoid that should come live with the key,if it starts then then you likely need an ignition switch if not you need the solenoid.
May 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
