Power works, inside tries to move, then lights in front blink
My problem was NOT a printer, instead a scanner.  The assistant did not understand the problem.  While trying to explain the problems, the scanner decided to work.
I will never ever select your web again.  I will discourage other from using you.
wsf1968
Posted on Sep 12, 2008
My sensor touch buttons don't work....any ideas why?
With Power on Microwave There is Light Blinking It Means Is Normal Power Supply Supply Problem,Not Reaching Front Panel Power Supply
Feb 07, 2014 | LG LMV2015ST Microwave Oven
Hello, I have an 56' Mitsubishi 1080I television. Model #55859. We moved the TV across the room last night and now we cannot get it to turn on. All we can get is a flashing green timer light on the front,...
Hi rteague2566,
The flashing light indicates something is wrong. Have you tried pushing AV reset button on the front panel of the TV. You may even try the little pin hole reset by the power button too. I think you may have bumped or, vibrate it to hard in the move and, caused the lamp or lead wires to become lose or, unseated. You may have even damaged it. Did you move this TV when it was still warm? Is the light blinking fast and, can you hear anything going on inside. Usually the DM board fails or, a few capacitors need replaced with this model.
If you still can't get the TV to turn on after the reset buttons have been pushed. Can you read the blink code. It should blink, blink, pause, blink, blink, blink. That would be a blink code of 23. Count the blinks in between the pauses. Let me know what code you get. If it just blinks real fast it is probably the DM. I kind of think you may just need to re-solder the leads. A DM cost about $250 with labor. When you plug back in and turn the TV on, let it blink for a few minutes, it might come back on. I'll wait for your response to give further instructions.
Jan 26, 2011 | Televison & Video
Power problem .... tried 3 different power supply cords...the green light on the rear blinking meaning???? pushed switch on front ...held in.....no response only moved from 1 office to another....always...
was it dropped..?? the indicator light should b solid not flashing.. If you held the power switch in for several min an nothing Try plugging the cord directly into the wall. Do not use power strips as they may have failed.Toggle the voltage regulator switch from 115V to 230V then back again. If you are in North America, this switch must be on 115V. you may have a loose connection in the machine Lastly, you may need to go inside the case and confirm the thin wires running from the front power and reset switches are connected to the motherboard., to check be sure u are grounded an check all connections inside the computer... If the LED is still flashing, the power supply is probably bad.
Apr 28, 2010 | HP Pavilion a350n PC Desktop
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
LQ-2180 printer is Continues blinking front panel lights.
The LQ2180 blinking lights can be caused by paper jammed, printhead overheated, paper loaded not detected and cover unclosed. Try to check all this first, you may have a fragment of paper stick to the sensors, or broken sensor. If all of the light flashing try to check the carriage movement, move it side to side, but with power off condition. If the carriage movement not smooth or stuck, look for any foreign matters inside the carriage path that blocking the movement if not, try to lubricate the rail which hold the carriage. If this doesnt solve you, the machine require parts replacement.
Apr 14, 2008 | Epson LQ-2180 Dot Matrix Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Cannot remove yellow blinking light
does the printer cycle?
unplug the power from the outlet and plug back in.
Can you look and see any paper inside?
when you lift the cover does the cartridges move?
Dec 06, 2007 | HP DeskJet 690c InkJet Printer
My laptop armada m700 gets no power
the hard drive was damaged. Inside the drive, the tiny moving head took the hit. They really are not designed to take shocks like that. Many laptop mfgrs offer "industrial" duty laptops that have on-board shock absorption suspension for hard drives.
Aug 26, 2007 | Compaq Armada M700 Notebook
19 people viewed this question
jasbo
jasbo
