Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
Hep where can i find the wep kep on the 2 wire? they said that i can find it on the 2wire wireless adapter
The wep key is located underneath your 2 wire gateway enclosed with a bracket.
Posted on Oct 10, 2008
If you are using at&t U-verse, then the WEP key is on a sticker on the gateway computer provided by at&t
Posted on Sep 13, 2008
    President:
  • 2,961 Answers
No, it's normally on the router side not the adapter
Posted on Sep 11, 2008
Would this wireless card be compatible with my current 2wire router? Linksys WMP600N Wireless Adapter with Dual-Band IEEE 802.11a/b/g, IEEE 802.11n Draft 2.0 PCI WEP, WPA & WPA2 Personal, WPA &...
It should be within the specs that you have provided it should be compatible... tha only thing that isn't compatible is the IEEE 802.11n 2wire is IEEE 802.11a/b/g
either you customize the setting for 2wire or disable the WEP
here's some link that might help you configure you're 2wire wireless modem
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
Aug 28, 2011 | 2wire 2700HG-B Router (2700HGB)
Help setting up Panasonic DY-WL10 wireless adapter to 2Wire gateway 2701HG-B?
go to on screen "setup"
select "network"
select "Network easy setting"
Select "wireless"
do the connection check
the 2wire modem should be detected by the DY WL10
Select the 2wire
select "open system"
select WEP encryption
enter the encryption key, or just "key" (it is the number in brackets somewhere on the 2wire). Do not enter the brackets.
follow further prompts. It is easy from here on (famous last words)
Aug 15, 2010 | Panasonic DYWL10 Wireless LAN Adapter for...
Wireless Internet through 2Wire router not working
First of all change your router to WPA rather than WEP. WEP is easily cracked now and is not secure. That might be what your laptop is looking at.
Secondly, update the wireless drivers to the current version from the website.
Make sure your router is broadcasting on 'auto' (802.11a/b/g, and N if supported), It ay be broadcasting only on, say 11g and your laptop doesn't support it. Updating the wireless drivers may also fix this.
Jun 23, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Where do I find the wep code for my 2wire wireless router
It is on the bottom of the 2wire gateway on the barcode. It is a 10 digit number that say wireless network key
Jun 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Installing wireless adapter for xbox 360. Asks for wep code
Hi!
You can see this link for the procedure--
Xbox Connection settings
Also see this link for details---
Xbox wireless
WEP code will be provided to you by your comcast. Check this link for wep key---
Comcast
and
WEP Code
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I need some simple help. I want to change my WEP Key so that someone who had the wepkey cannot access my wireless network any longer. My router is a 2wire...can you help?
Hi Steve,
Do you use a Wireless Router? If so, logon to the router, go to wireless security and change the wep-key there.
If not, do you host the wireless network on your PC?
What kind of Router do you have if you have one?
Regards Ronnie
Jan 11, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Installing 2Wire usb adapter to a Linksys 802.11b wireless router
My first suggestion would be to get rid of the 2Wire adapter. The other part is not quite so simple though. First question, Do you have WEP enabled on the router?
Oct 30, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
74 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
