Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
No power Our 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
  • Anonymous Sep 25, 2008
    We had the same problem. Replaced the fuse and it worked, but then on the very first cycle it did the same thing. Fuse blown again.
    Novelist:
  • 171 Answers
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
2 Suggested Answers
  • 530 Answers
SOURCE: dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Posted on Jan 04, 2009
Turned on the 1 hr button and it did start but after a few minutes it stopped. None of the controls are lit and the water is just standing in the bottom. What do I do to get it started again?
If it fills with cold water, it will pause and try to heat the water... if there is no heater function, it will never achieve wash temperature.
To invoke the Diagnostics Cycle, perform the following while in standby:
? Press any 3 keys in the sequence 1-2-3-1-2-3-1-2-3 with no more than 1 second between key presses.
? The Service Diagnostics Cycle will start when the door is closed Whirlpool Dishwasher High Limit Thermostat WP661566 , Whirlpool Dishwasher Heating Element W10518394 , Whirlpool Dishwasher Control Board W10751502
Jul 12, 2016 | Whirlpool Dishwashers
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Dishwasher will not turn on,
OK check Fuses/Breaker.
Check there is actually power to the outlet, try another appliance in the actual outlet.
Try this below...
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle.This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method,
If none of the above work etc, then my advise is to get a serviceman to call. Contact a Whirlpool agent, and when they call, ask for a "quote" before allowing any repair work to be undertaken.
Manual link below. http://www.retrevo.com/support/Whirlpool-DU1100XTP-Dishwashers-manual/id/8232ci774/t/2/
Mar 02, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
8 yr old GU1200 stopped mid cycle - no apparent reason - no response to buttons - appears dead?
These dishwashers have a thermal fuse in the control panel. If it overheats for some reason (sometimes a bad connection on the fuse itself causes that)it will turn whole machine off.
  1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
  2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse. Here is your part
Good luck
Vlad
First Choice Appliance
Sep 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Inside of dishwasher was dirty after cycle, baskets had black in between the screen...took out all bottom and found dirty water, a couple of inches and slime in bottom...cleaned it all out and put it back...
Check the food grinder (small blade spins against a screen) in the bottom of the dish washer drain. I found the grinder to be inoperative and clogged which reduced / stopped flow of the wash water. Also, small pieces of clear plastic food wrap can block flow.
Sep 18, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
JET TECH/model F18/small amount of water stays in bottom.Wont fill or cycle but water runs.
It is normal to have 4 or 5 inches of water inside the dishwasher unless you remove the stand-pipe (located inside, front right side). This pipe should be removed at least once a day and the dishwasher should be drained. Don't forget to turn the power off first.
For more info goto to
http://www.mvpgroupcorp.com/jettech/support.htm
Robert
May 11, 2009 | Jet Tech Systems 24 in. F18DP...
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher stopped mid-cycle
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
704 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
