Question about Lands Phones
RCA model # 25415 answering machine problem
I have one base with answering machine and one cordless. Everything worked fine for a year and now I can't get the answering machine to work. It rings and rings and the answering machine doesn't pick up, just silence. I have the "answerer" button lit and all the plugs are properly connected.
I also noticed on the top of the display window it reads.... (02) Station
I'm wondering if that should be station #1 as it is our main phone and the only one with an answering machine. I don't know how to change the station # and can't find it in the manual.
Any help is greatly appreciated!!!
SOURCE: BT Synergy 2150 Cordless Phone
As far as I can understand your problem, there is nothing wrong, just view the new calls ( options/caller id/options/view/ up and down arrows to scroll through caller id's). New calls message will then disappear, although it doesn't really matter if you don't do any of this.
Posted on May 15, 2007
SOURCE: ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Posted on Jan 15, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
  • 18 Answers
SOURCE: E4 code on base station
i know that you dont want to hear this but that means it must be replaced. you should be able to get a replacment form where you purchased the phone
Posted on Jan 09, 2009
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Posted on Mar 03, 2009
Our DECT 6.0 4 phone system has been working fine for well over 1 year. All of the sudden when you dial out and the person on the other end answers they can't hear you. If someone calls here you can hear...
Sit the headset units back to the main base one by one.
Make sure you do all of them at the sametime.
This will reset the DECT 6 security feature.
Swap out the rechargeable battery to rule out weak battery problem.
Oct 22, 2013 | AT&T DECT 6.0 Cordless Phone System with...
I can't figure out how to record message for answering machine
There should be a greeting or greet labeled button on the base.Hold it down and it will prompt you.If there isn't one,without turning on the phone hit the funtion button.There should be a directional button to cycle you through the options.It should be on the base though.We just got rid of our Uniden though because the batteries died and there are so many new ones that come out year to year,they don't even put out the battery anymore.It is less than 2 years old too.:( Good luck!
Jul 14, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
We use an RCA 25415 in our office and can not get the intercom to work, any suggestions?
http://www.rca4business.com/products/pc/pdf/instruction-book/25415RE3.pdf
If you click on the above that is your manual.
go to page 10 for Intercom auto answer.
and page 19 for Intercom calls .
Hope it helps!
Jan 12, 2010 | RCA 25415RE3 Phone
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
Lands Phones Logo
51 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
