Question about Uniden BC72XLT Handheld Scanner
What Type Of Scanner Do I Need?
I am totally new to the scanning world, So light explanations please. I visited a site that has the info for the local police frequencies etc. for my community, And it states this: "These are conventional P25 channels. This is NOT a trunked system." What exactly does this mean? What kind of scanner would i need to listen in, A Digital one? I'd like to know because im planning on buying a scanner and have it professionally programmed for my area, But just need to know what type first. I live in Canada too. Thanks.
  • 211 Answers
Well, the above answer is somewhat correct, but could use a little clarification.
A radio that transmits in a P25 format is digital. Digital transmissions can be trunked, but don't have to be (as is the case here). In the case of scanners, every major brand scanner out there that works on digital transmissions will decode trunked of conventional digital and analog transmissions.
The current digital models run anywhere from $399 to $599. Radio Shack has 2 newer models out that will do digital...the PRO-106 (handheld) and the PRO-197 (base/mobile). These have been on sale recently for $399. Uniden also makes digital trunking scanners..the latest models being the 396 (portable) and the 996 (base/mobile). While the 996 has the capability to be used with a GPS in a mobile setting, this feature isn't really worth the added cost, especially when compared to the feature rich PRO-197.
There are older model digital scanners, such as the Radio Shack PRO-96, PRO-2096 and the Uniden 250D and 796D. While these receive digital transmissions, the newer scanners have upgraded digital decoding algorithms that provide better audio quality and intelligibility. Also, the older scanners may not be able to decode the 700 MHz public safety band, which is becoming increasingly more popular since the 800 MHz band is quickly filling up.
One word of caution...be sure that the agency you are trying to monitor is not using encrypted transmissions. If you don't know...look up the system on radioreference.com. Channels that are encrypted usually have an "E" designation under the "mode" column. These transmissions CANNOT be decoded by any of the scanners currently on the market, even if you do have the encryption key.
I hope this helps you with your buying choices. Good luck!
Posted on Dec 07, 2008
  • 405 Answers
Good Day,
You should find out if your area may be upgrading to a trunked or digital system. I say this because right now you can purchase a traditional am/fm scanner and it will work in your area without any problems, however if your local area upgrades to a trunked or digital system your conventional scanner will not work. Conventinal scanners can be purchased new for around 100 bucks or less where as trunked scanners are in the 150 - 250 range and digital scanners are around 500 bucks.
So if know they are not going to upgrade to trunked or digital just get a conventional scanner and you are all set, but if they are considering an upgrade you may want to get a digital. And a digital scanner will pick up trunked and convention frequncy's. But a conventional will not pick up trunked or digitla.
Hope this helps
Check out this link for a general scanner FAQ
http://www.advancedspecialties.net/radio-scanner-faq.htm
Posted on Sep 11, 2008
How to repair a check engine on a 2005 dodge ram 1500
When "cjeck engine" light turn on, means that some fault code is stored in the PCM (computer) you will need scaner the PCM to know exactly what code is there; sometimes Autozone or AutoShop with scanner reader make this job for free. With this code number we could send additional details to diagnostic and solutions.
Keep us updated.
Jun 09, 2011 | 2005 Dodge Ram 1500
Hi,Ive been trying to set my icf-cd2000 clock radio,I downloaded info,It is so small I cant read it.(ive tried to make it larger on photo copier) but it only blurs ,can I buy a manual please,Or do you have...
Setting the Local Time
  1. Press WORLD/LOCAL to display "LOCAL".
  2. Hold downl CLOCK until you hear a beep.
  3. Press TUNE/SCAN TIME SET + or - to set the hour.
  4. Press CLOCK to enter the hour.
  5. Press TUNE/SCAN TIME SET + or - to set the minute, and then press CLOCK. Two beeps sound to confirm the setting.
Setting the WORLD Time
  1. Press WORLD/LOCAL to display "WORLD".
  3. Press TUNE/SCAN TIME SET + or - to set the desired hour and press CLOCK. Two beeps sound to confirm the setting.
If you need any more help, feel free to ask.
Mar 08, 2011 | Sony ICF-CD2000 Clock Radio
My scanner (radioshack Pro 2018) doesn't receive signals from local poloce, ambulance and so on. What do I need to do?
First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
www.RadioReference.com
The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
Bill B
Aug 10, 2010 | Radio Shack Pro-2018 Scanner
How do i get the channels to my pro-137 scanner
If you're looking for frequencies to program into the scanner your best bet is to visit
The site has a comprehensive database of active frequencies, by location, and a lot of other useful scanning info.
BillB
Feb 08, 2010 | Uniden BC350C Base Scanner
I have a pro 38 realistic scanner i need local reno area police frreqs
For a comprehensive database of active frequencies and systems in your area, plus a lot of other useful scanning info, visit
BillB
Jan 31, 2010 | Radio Communications
My bearcat bc-210 wote scan . How do i get it to
From your request I can't tell if the scanner has a problem or if you just need to program the correct frequencies into it. If you need the frequencies for your area, please visit
or
www.CityFreq.com
for an extensive database of active frequencies and systems in your area. NOTE: Any trunked or digital systems in your area cannot be monitored using the BC-210. If your area has switched to these newer systems, you will need to upgrade to another scanner to follow all the action. If you have any other questions concerning your scanner please give us another shout.
Dec 04, 2009 | Uniden BC244CLT Base Scanner
My check engine light is on , how do i get the code ?
got to an auto parts store and they will loan you a scanner. Scan it and then tell them the code and they can tell you what you need.
Sep 30, 2009 | 2005 Dodge Dakota
Scanner
to be able to scan to pc you have to have the scan file utility set up on the pc
the scan file utility is on the CD that came with the copier.
you can Google the file if need be
when you have loaded the file you will need to go to
start, all programs,kyocera (scanner file utility and open it
once in configuration you will need to do the following
select setup
on the top you will see a box, type in 001
file destination, you should hit the box next to this and select kyocera/scan file
press ok and you are done
Next
get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
get back into normal copy mode
on your web browser type the scanner ip into the address bar and you will get into the scanner command center
press the start icon bottom left of your desktop, go to run and type in cmd
once in dos mode type in ipconfig, this will give tou the destination address for your scans
now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
say no to all password requests
and submit
very important now is to close the browser as you cannot scan when the command center is open
please take the time to rate this fix
Mar 27, 2009 | Kyocera Office Equipment & Supplies
Programming scanner
go to www.radioreference.com and find the forums page, then go to the radio shack scanner forum and you will find anything you need to know there.
Sep 15, 2008 | Radio Communications
Uniden BC72XLT Handheld Scanner Logo
1,606 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
