Question about Kodak Office Equipment & Supplies
Why cant i print envelopes - Kodak Office Equipment & Supplies
  • Kodak Master
  • 1,879 Answers
Well that depends, additional info would be great.
Here's an example:
PRINTING ENVELOPES from Microsoft Word
The envelope should be fed into the printer using the short side, all the way to the right, flap to the back and to the left.
Please follow the steps below to print envelopes in Microsoft Word:
1. Open Microsoft Word.
2. Click on TOOLS, then ENVELOPES AND LABELS.
3. Ensure the ENVELOPES tab is selected. Click on the OPTIONS button.
4. Select your envelope size under ENVELOPE OPTIONS (ie: #10).
5. Select PRINT OPTIONS.
6. Under FEED METHOD, from the six options available select the FOURTH icon from the left. Select FACE UP.
7. Ensure CLOCKWISE ROTATION is selected.
8. Under ENVELOPE OPTIONS, ensure you choose the correct envelope size (ie: #10).
9. Click OK, then PRINT.
The envelopes should print correctly now.
Posted on Sep 11, 2008
How to print envelop on HP 3390
you would be better using sticker sheets.
see for an example
http://www.officeworks.com.au/shop/officeworks/c/office-supplies/labels/address-labels
your local office supply shop would have something similar
Some labels have downloadable templates to make it easy to line up the addresses to the laser label sheets
Trying to print on the envelope could cause jams inside the printer
Aug 13, 2016 | HP LaserJet 3390 Printer
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
I want to print envelops on my office canon imagerunner 5570. i cant? help.
use the stack bypass for envelope printing.there u can choose the paper size as envelope depending on the size and also u can set ur own XY size for the envelope
Jun 03, 2011 | Canon imageRUNNER 5570 Copier
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
How to print envelopes on clc 5000
this not necessary a software because this machine have got that funcion on setting to bypass and casset
Feb 10, 2009 | Canon CLC 5000 Copier
Unable to print envelopes
On the word program you should change the size of the page to fit to an envelope, otherwise it will not work.
Dec 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Xerox Doc 12
should be ok if you use the bypass
Jul 31, 2008 | Xerox DocuColor 12 Color Copier
Put envelope in bypass tray. Print on it.
Jul 23, 2008 | Brother Office Equipment & Supplies
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
1,625 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
