Question about Cobra 29 LTD CB Radio
Frequency Bought a cb from the states was told it would work ok in the uk only to find out it is an am freq and freq for the uk is fm can cb be changed to work in uk
  • 405 Answers
You would have to replace several components on the board(requires alot of soldering and the parts needed are a little hard to come by) in order to change the output frequency ranges. It is alot of work to do this and is probably not worth all the work, Best advice I can give you is to replace it with an AM one and sell it.
Hope this helps
Posted on Sep 11, 2008
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Tip
Building your own Antennas
To build antennas for any frequency use formula L=234/Freq. Lets say 100 mhz. That would be L=2.34 feet or about 30 inches(close). Ok, Build a dipole antenna with a plastic insulator and 75 ohm Tv Coax. Take stiff alumnium rods or wire. Punch a hole into a plastic piece 4 inches apart. Insert Rods on both sides. Take shiny screws (Not Painted). attach Center Coax to Right side and Shield (ground) to Left side. Silicone these connections and use Black tape to wrap it good. Mount it on your Chimney or on a Tv pole 12-25 feet. Now, the coax coming into your house has to hook to your stereo by a 75 ohm match coil bought cheap at Electronic stores or Tv, radio supply stores. Attach coax by screwing it to coil and the two prongs screw to Back of your Fm Stereo. It will say ANT and GND. on back of Radio. You should pull in Fm stations better than indoor antennas and get farther away stations. It may have a 3 Db gain. Its the same for Cb radio --Just Use L=234/Freq. it comes to 8.5 feet(102 inches) Roughly. Its all Dipole Technology ..No Commercial antenna but will get decent results.
on Apr 01, 2011 | Audio Players & Recorders
Midland 75 785 purchase from us will it work on uk channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-785 Handheld CB Radio
Cobra 19 DX IV, I bought this unit in america, but i live in the U.K. and can't pick up any channels, does this unit Only work in america, can i get somthing for it to work in england??? Thanks...
  • The UK uses more FM frequencies than AM frequencies. So the CB will work over there just fine but you will need to find someone who uses them frequencies as well or it may no be much fun. Here is a frequency chart for what we in America call import radios shipped from over there. http://macuk.org.uk/cbchart.htm 27.555 FM is the main frequency used in the UK but the Cobra 19 is a strictly AM CB. Also on the link on the far right are the standard 40 channel frequencies from the UK version of CB's and not one is the same as the Cobra 19 as the UK uses FM for their 40 channel CB radios.
  • Here is the 40 channel CB frequency chart utilized in America http://www.csgnetwork.com/cbradiofreq.html
  • Hope this clarifies things for you.
Regards, Tony
May 18, 2011 | Cobra 19 DX IV CB Radio
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Sideband freq
That is wrong , I used to have a freq. counter that only read when you applied RF to it on my old Tempo rig and I ran lower 37 and upper 35 so I would key the radio on am and tune the vfo to that frequency and would be on frequency with everone else,I remember hearing that once long ago but it's not true.
Feb 21, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
1998 Wrangler Sahara - radio not recieving low freq FM Bands
if you are receiving stations on the higher frequencies then your radio is the problem and not your antenna or anything else
Jan 13, 2009 | 1998 Jeep Wrangler
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Magnum S9 10/11 mtr radio
If you're receiving OK on AM & SSB, the likely adjustment would be the FM discriminator coil L5. You can adjust it for maximum noise with no signal applied.
Mar 22, 2008 | Magnum DeltaForce CB Radio
Cobra 29 LTD CB Radio Logo
82 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
