Question about Sanyo Microwave Ovens
Sanyo EM-D9552 microwave oven with super showerwave fan oven and powergrill. Microwave does not always work. Sometimes you may be lucky but mostly not. Any thoughts would be most welcome.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Posted on Nov 21, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Displayd LOC Code
The first step is to unplug it from the wall for a few minutes then try again.
In case it helps, model EM-S5595 is unlocked by holding the Stop/Clear button as in the photo below.
If that does not do it, try Sano/Fisher Service at http://sanyoservice.com/ .
You may also have a keypad or control board problem.
Posted on Oct 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: new oven door needed sanyo EM-SL100N
That would be a UK model. No wonder I had so much trouble finding it.
You can get parts here:
http://www.chsinteractive.co.uk/microwave_ovens_parts/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
SOURCE: REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Posted on Apr 11, 2009
sonicboomele
  • 1557 Answers
SOURCE: How to install new light bulb
unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
good luck
please rank me ..
Posted on Jul 04, 2010
Sanyo microwave windmill super showerwave EM-3490W. TOUCHPAD NOT WORKING
The touchpad may have failed but a defective connection should be considered.
Sep 12, 2017 | Sanyo Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Sep 09, 2012 | Microwave Ovens
I need a user manual for a Sanyo super showerwave 800w microwave. Model no. EM-G204 There aren't any on manuals online. Thanks Luke.
You can just type "EM-" (without quotes) in the search box at the Sanyo (Panasonic) support site here.
Check a few of the first results to see if they're close enough to help you.
If not, contact them via that page for more help.
Aug 22, 2012 | Microwave Ovens
How do i unlock the control key pad on a sanyo super showerwave
Try holding down the Stop button for approximately 5-10 seconds. This is the industry standard for locking and unlocking microwaves, although your Sanyo may vary. Please let me know if this helps!
Mar 01, 2011 | Sanyo EM-A5200SW Microwave Oven
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Sep 16, 2008 | Microwave Ovens
New oven door needed sanyo EM-SL100N
Jun 29, 2008 | Sanyo Microwave Ovens
Nov 20, 2006 | Sanyo EM-P790 Microwave Oven
Microwave Ovens Logo
175 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
