Home | Emerson | EWD2003 DVD Player / VCR Combo | Dvd audio quieter tha...
Emerson EWD2003 DVD Player / VCR Combo
Problem for Emerson EWD2003 DVD Player / VCR Combo
Dvd audio quieter than vcr audio
By karokegene on Apr 22, 2006
When operating the unit in DVD mode the volume is very low. When operating in the VCR mode the volume is normal(noticable louder). Have tried different outputs(coax and RCA) still no volume or low volume in DVD mode.
Same Problem
Mar 23, 2009
-   The VCR part is fine but when we switch over to the DVD it is noticably quieter.  -   asolvie
Solution #1
posted on May 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have found that I can increase the sound on my unit by changing the channel on the TV to Input 1. This increases the sound volume and quality with this unit, but does not bring it up to VCR volume.
Solution #2
posted on Apr 22, 2006
Not Rated)
techman
Rank: Guru
Rating: 86%, 7624 votes
There may be an audio adjustment in the dvd player that wasenr set up at the factory correctly. depending on how old the unit is I would contact the manufacturer and see if its under the factory warranty as you DO NOT wanna go inside and start turning controls as this will or could throw the entire alighnment out of the dvd player. I(f theres no warrantee then you could ask them if theres an audio output adj and what the pot # was. Or else your gonna need to get a service manual and throw ya back a few bucks. But my guess is that if you bug the service guys enough they will tell you where the adjustment is. Good luck
Was this helpful?
Yes
No
Popular Solutions for Emerson EWD2003 DVD Player /
Questions and Unsolved Problems for Emerson EWD2003 DVD Player /
Do you recommend Emerson EWD2003 DVD Player / VCR Combo?
Answer
Answer
My VCR will only play or record for 16 seconds then it ejects out. How do I fix this? or what is... (More)
Answer
How do i record on the vhs tape if i have a satalite dish
Answer
When I switch over to the dvd player we can barely hear the sound with the volume all the way up. ... (More)
Answer
I need to play dvd's and they won't play because of the parental control which is on and I can't... (More)
Answer
the vcr part on my player will no longer record. we have satellite and we have replace one of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Emerson EWD2003 DVD Player /...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
