Question about Razer Copperhead RZ01-050100-R1M1 Mouse
Left click is broken
My left clicker on my mouse is broken. When I press down on the mouse it either double clicks or doesnt click at all. This is really aggravating all of the time and especially when playing counter-strike. Is there some way i can take it apart to fix it or should I just fork over some cash for a g5
  • 3 more comments
  • ssnumber19 Sep 12, 2008
    i ended up fixing my mouse...if anyone else has this problem what I did was just take it apart and superglue a bump where the top of the mouse makes contact with the left click inside the mouse...if anyone needs additional help with more details just post here.
  • hOzAy209 Sep 18, 2008
    how did you open up your razer copperhead? i've been having issues with mine too, it double clicks randomly and razer won't fix it cuz it's not under their warrenty no more, it's so annoying that i've stopped using it and went back to my old optical mouse
  • NKurland Dec 14, 2008
    Mine is the right click, but same prob. I would take it apart thingking it needed cleaning but I see no screws or catches to open it. any ideas?
  • pharaoh72002 Jan 03, 2009
    yeah same problem here too. what's the best way of opening it up?
  • Anonymous Mar 13, 2014
    My left clicker on my mouse quit working although it is practically brand new. Is there a way to take it apart and fix this or any other easy way to fix the mouse so that it will left click again?
I came across this post while having the same double-click issue with my copperhead. I've found that the cause is the plastic contact under the left click button itself. It wears out and takes on the shape of the microswitch underneath. To fix it all you have to do is follow the instruction for taking the mouse apart posted above and lightly filing the plastic contact flat again. You only want to take the notch out of it.
Posted on Jan 25, 2009
How to open the mouse (will probably void warranty):
* you need: a crosstip screwdriver, a pointy tool (like a small screwdriver), pincers
- unplug the mouse!
- remove the rear foot of the mouse using the pointy tool and pincers. Do not damage the foot nor touch the sticky side!
- remove the "QA" sticker from the hole where the foot was before, use the pincers for that
- remove the screw in the hole
- lift the rear end of the lid of the mouse about half a centimeter
- pull the lid back to unhook its front
You should now have access to all relevant parts. Avoid touching electric contacts when possible.
To close the mouse:
carefully place the fiber optics back in their groove, hook the lid in at the front, push the lid forward, close the mouse, put the screw back in, put the "QA" sticker back in, place the foot back.
I don't know about the click problem or the glueing of bumpers, I only had to fix my mouse-wheel.
Posted on Jan 13, 2009
Soem physical abuse solved this issue for me. I banged my copperhead with the plam of my hand. Haven't had the problem since.
Posted on Jan 23, 2009
Please explain the process. don't want to go flinging glue around and mucking up this ancient pos mouse, haha. even a pic with a circle around the area would be cool, and there are stock photos and mspaint to help thar. don't know what i'm doin.
Posted on Oct 08, 2008
Can't click on right
Hi!
That depends on the quality of the mouse that your using.
Cleaning/ opening the mouse will not work at all.
The quality of the mouse.
Jan 25, 2014 | Kensington Expert Mouse Trackball
Mouse clicker buttons not working
In Control Panel there is a mouse section, you may have the clicking disabled. if you don't and it still isn't functioning then you have a bad touchpad and it will need to be replaced.
You can also test using a USB mouse to find out if you have clicking disabled.
Feb 26, 2013 | Computers & Internet
The left mouse button doesnt work every 4th press...
I believe the switch inside the left mouse button has worn out or broken that made you think after pressing 4 times you were able to trigger the switch and make the mouse to work. You may open your mouse carefully to see if this is the case. If not please follow the below steps as you might need to configure the mouse double click speed.
Open control panel>Double click on the mouse icon>Button Tab>Double Click section>Adjust your double click speed.
Jul 19, 2011 | Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Mouse left button not working have to press hard for it
you are losing your mouse sorry or maybe need its time to cleaned.. good luck pls click if my solution was usefull
Dec 27, 2009 | Microsoft Wireless Optical Desktop Comfort...
Touch pad working fine but left clicker doesnt
Usually the green means that the button is pressed. Check the touch-pad buttons for dust or dirt. If they're clean, then probably need to be repaired.
Aug 26, 2009 | Computers & Internet
Actually, first you should try taking the mouse open and cleaning the sensor clicker thing or whole mouses insides, I had similar problem before, that fixed it for me.
Other option which I haven't tried and am not sure if works, you could try to move one of the side buttons that you don't use sensor to the place of the left mouse button. This I HIGHLY advice against tho since this might break down the mouse totally.
Then again if it comes down to not properly working mouse and you have to get new one versus broken mouse and you have to get new one, you have nothing to lose.
Jun 11, 2009 | Razer Copperhead RZ01-050100-R1M1 Mouse
Context menu continually pops up - mostly when left mouse button is clicked sometimes when keyboard is used. Context menu key doesn't work.
I think the mouse setting is set to left handed and the right clicker is the main clicker and the left is the context menu key. Knowing this, you should follow these steps.
1. Go to "Control Panel"
2. Click "Printers and Other Hardware"
3. Click "Mouse"
4. Go to the "Buttons" tab and switch the setting to right handed
Jan 31, 2009 | Compaq Presario Notebook
Mouse will randomly double click or have to click several times to work
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
Oct 18, 2008 | Logitech Cordless Mouse
Rotating screen display
click again until screen is right. then open mouse config and turn off that button or change it's function.
Jul 01, 2008 | Logitech 9311570403 Mouse
Open Questions:
Razer Copperhead RZ01-050100-R1M1 Mouse Logo
3,013 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
