PCL XL error
Using HP Compaq 7700 with a kyocera FS 1300D displaying this error when printing in PDF format...the printer will print...eventually, but in the meantime it blocks everything from printing until information completes print job
PCL XL error
Subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Position: 25889
Try to go to property then setting device button PDL and try to put pcl 5e
Posted on Mar 10, 2009
Kyocera fs 1028 error pcl xl kernel error operator 0x6b position 938
PCL error is telling you that the printer does not understand the data being sent. Could be a corrupt or incorrect driver, or the program you are printing from is sending corrupt data.
Aug 28, 2015 | Kyocera FS-1028MFP
Why does my printer is printing pages that say pcl xl error input read error i need help
make sure you have the right driver if your printing from adobe go into adobe settings and print as an image
Jul 11, 2014 | Kyocera "FS-3140MFP Printer, Copier, Fax &...
Pdf printing
Your problem should be very simple, go to the printers icon from the computer side, right click on the kyocera printer icon,click properties, then click device settings, under device settings you will PDL, click on PDL and select PCL XL, click apply, okay. this will fix your problem.
Dec 06, 2011 | Kyocera FS-2000D Laser Printer
Dear sir / madam many times when i print, the printer give white paper and this error pcl xl error subsystem : kernel error illegal tag operator ox8 position 30374 what i must do thanks
try a different driver
pc5
pcl 6
and kyocera own kpdl or kx
or even a mini driver
here is the link http://www.kyocerasupport.co.uk/index/download_center.false.driver.FS1030D._.EN.html
if all fails u might need to upgrade firmware on the printer
Nov 20, 2010 | Kyocera FS-1030D Laser Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Error printing scanned
some files may be corrupt: Best is try to reinstall printer software with original drivers to ensure that correct files are installed.
Jun 08, 2009 | Kyocera FS-3900DN Laser Printer
I need the printer driver for my Kyocera Printer, Laser type,FS 3800N.. How to get it and save it. Please advise. Bud
You can also go to www.kyoceramita.com.  Go to Downloads and USA, select your product "Legacy Printers" then your model.  Then select print drivers.  I would suggest the KX Driver.  It is the fullY Fuctional driver that has PCL 5, PCL XL(PCL 6) and KPDL(PS3) built in.  It also has some good add-ons like Print to PDF.  Hope this helps, I've been a Kyocera Tech for 11 years.
Feb 18, 2009 | Buffalo Technology LPV2-USB-TX1 Print...
PCL Xl Error
when installing new driver choose PS ( post script) instead and see it fixes problem
Good luck
Apr 03, 2008 | Kyocera Mita FS 3800 Laser Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
1,129 people viewed this question
jasbo
jasbo
