Question about SanDisk Sansa e260 MP3 Player
Sansa e260 I was listening to my tunes this morning and my player suddenly turned-off on me. I had it connected to some external speakers. I thought it had run out of battery and proceeded to connect it to the pc's USB. No joy. Still doesn't turn on. Did it "fry" on me? Or...is there another possible troubleshooting method I can try? Thanks. Richard T
    Sergeant:
  • 300 Answers
I'll get right to the point.
Mp3 files loaded to the internet may contain errors , aka broken in some way which can cause an Mp3 decoder to fail , it can stop winamp in it's tracks , it can also cause electronic decvices like an ipod to just out right lose it's mind and shut down.
Everybody needs to check each file before it makes it to their playback device.
I used a program called encspotbasic 2.0 , it's an Mp3 checker which checks my Mp3 files for errors
before I play them back.
I'm also doing an investigation on ipods and mp3 players to see if they contain any HOT components
which may cause failure , or cause a breakdown of the player , as I suspect thats what happened in your situation , but never load an unchecked mp3 file because that can cause the overheat and cause them to stop working as a result.
I can't fix your problem without more information at this time , information that you may not be able to provide me with.
I really want to make guru expert status here because I like to help people with computers and electronics.
I feel very bad that you've lost your Sansa e260 player in such a brutal manor.
but if you'll follow the advice of checking each file with an encoder checker , it will serve you well.
I higly recommend using a portable coby 1GB USB mp3 player , they are VERY stable here in my lab.
Hope this information helps you in the future.
shalom >:D<
Posted on Sep 11, 2008
I think my sansa e260 just died
Is it unlocked? I thought my sansa died a few times, bit it turned out that it was just locked.
Sep 28, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 wont turn on indefinately.
did you try the lock on, rec button and the on button as you plugged it into the usb?
May 12, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 Car Connection Problem
Since I haven't heard back, I am going to clear this from my queue
May 16, 2008 | SanDisk Sansa e260 MP3 Player
Stuck in language mode
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Please help me!
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 key locked(?)
seems kinda obvious, but did you turn off the hold switch on the top?
Sep 18, 2007 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
Black screen no scroll light ????
I suggest that you hold down the power button for 15 seconds. It will reset it.
Feb 07, 2007 | SanDisk Sansa e260 MP3 Player
Audio Problems with Sansa e260
apparently you may need to defragment your player with disk defragmenter because the mp3 has a hard time getting the pieces of your file fast enough to not hear an almost unnoticeable pop or crackle. if this isn't the reason, it is probably the jack, try a different pair of headphones even. or check the settings on the program synchronizing as it may be syncing the files at a noticeably lower sound quality. Or you are drag and dropping which may not be recommended for inexperienced users. no offence :).
Jan 28, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
