Question about Palm Tungsten C Handheld
Keyboard data entry
When attempting to use keyboard to enter data to date book or address book - get weird results. Datebook: When initiating or editing any entry in datebook, pressing (even touching) any character key causes cursor to jump to a new "floating appointment" line, which accepts exactly one character. If you press a second key, you get a second new FA line, which accepts exactly one character, and so on. Address book: When entering text, the last two keys in each row cause unexpected jump to bottom of page - no character is entered. When using Memo Pad, all keys/characters work just fine.
  • 513 Answers
Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- http://www.palm.com/us/support/downloads/tungstenc/tungstenc_update_30.html If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
Posted on Apr 23, 2006
I have a XEROX WorkCentre 5638. How do export the existing address book to add addition email address to it?
This model does not support exporting of the address book. However editing of the address book is very easily accomplished by following the steps below.
We encourage you to use our knowledgebase http://mrc360.com/XeroxKnowledgeBase
These instructions link is here: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=477,E=0000000000016114582,K=3962,Sxi=6,Case=obj(23672)
Solution : Add or Remove Addresses From the Public Address Book Using CentreWare Internet Services (CWIS) To add addresses:
  1. Open an Internet browser window on the desktop.
  2. Enter the IP address for the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services (CWIS) window will be displayed.
  3. Click on the [Address Book] tab.
    NOTE: If prompted, enter the username and password in the fields provided, and then click on [OK]. The default username is "admin" and the password is "1111".
  4. Select [Add New Entry].
  5. Enter the friendly name and the e-mail address for the new entry.
  6. Click on [Save & New] or [Save & Close].
  7. Click on the [Logout] link and logout of CWIS.
  8. Close the browser window.
To remove addresses:
    NOTE: If necessary, enter the username and password in the fields provided, and then click on [OK]. The default username is "admin" and the password is "1111".
  4. Click on [View All Names].
  5. Click on [Delete] next to the name you want to remove.
  6. Click [OK] to delete.
MRC
Jan 12, 2015 | Xerox Office Equipment & Supplies
Acer laptop problems with typeing
First thing try swapping out your keyboard with another; if problem stops you possibly have dirt in the keyboard-needs cleaning or possibly replacement. If problem does not stop and your keyboard is USB try a different USB port to plug in to. If problem still does not stop try a system restore back to a date before this started. If that does not help, try entering safe mode. If problem stops something is loading that is conflicting with the mouse. Enter MSconfig and disable all load entries, reboot and see if problem stops. If it does, enable each entry 1X1 until problem starts again and you found the problem. That should get you started.
Jun 14, 2013 | IOGear GKM541R Keyboard/Mouse
Samsung s8300 how do i speed dial using keyboard
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: [most of this from Phonebook/More/Settings/1 ]
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jan 30, 2010 | Samsung S8300 Ultra Touch platinium-red...
Downloading latitude and longitude
Do you want to enter them manually, or via USB?
To enter a location manually, using only GPS coordinates, try the following: Create any entry in your address book - it doesn't matter what you enter since you will be totally changing it anyway! Then 'edit' the address book entry that you just created, putting what you want in each data field. Finally, edit the GPS coordinates for this address book entry (note that you have to overwrite the whole entry, beginning with N, S, W, E and then the numbers). Save your changes and now you have an address book entry for that rig.
I do not know how to download this directly using the USB connection - sorry.
Jun 29, 2009 | Lowrance iWAY 600C Car GPS Receiver
Speed dial
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Need to add employee e-mail address to xerox 440st so we don't have to type it in each tme
NOTE: Accessing the Public Address Book is optional. The Document Centre will accept a Public Address Book file that contains a list of user names and their E-mail addresses. This file must be Comma Separated Values (CSV) format for the device to be able to read the file contents. The majority of word processing packages will allow you to create a CSV file. A selection of e-mail applications will also allow you to export a list of users in the CSV file format.
The completed CSV file is imported to the device through CentreWare Internet Services. The file must have the .CSV file extension. A valid CSV file format includes the name and SMTP e-mail address. The CSV file should be created so that the Names are in one column and the E-mail addresses are in the next column. For example, the following are both valid format CSV file entries:
Smith, Smith@company.com
Smith, John - john.smith@company.com
The order in which entries are displayed in the Public Address Book at the Document Centre will depend on how the entries are sorted in the CSV file.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system. Configuration of the LDAP directory settings requires the network to support LDAP Services.
The Document Centre will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a Configuration Report and make sure the Document Centre has an IP address and the HTTP protocol is enabled.
From the workstation desktop:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to launch Internet Explorer.
  2. Click on [File] from the toolbar, then select [Open]. The Open window will be displayed.
  3. Enter the IP address for the Document Centre in the Address: field, then press [Enter] on your keyboard. CentreWare Internet Services window will be displayed.
  4. Click on [Index] in the upper, right corner of Internet Services. The Index window will be displayed with a list of hyperlinks to different areas of Internet Services.
  5. Click on [Public Address Book ] from the list of hyperlinks. The Public Address Book Settings window will be displayed.
  6. Click [Browse]. The Choose File window will be displayed.
  7. Browse to the location of your Address Book File (*.CSV).
  8. Highlight the CSV file and click on [Open]. The path for your .CSV file will be displayed in the Address Book File (*.CSV) field.
  9. Click on [Import Now]. An 'Are you sure you want to overwrite the existing Address Book? This cannot be undone' message may be displayed. Click [OK] to import the address book.
    NOTE: You cannot import a .CSV file with a blank name or e-mail field.
  10. An Enter Network Password window may be displayed. In the User Name: field, enter the system login of admin, in lower case letters. In the Password: field, enter the system password, then click [OK].
    NOTE: If you do not know the system password, contact your administrator. The initial system password at machine install is 1111 for the Document Centre 460|470|480|490, and 22222 for the Document Centre 425|430|432|440. If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed.
  11. Click on [Map Existing Address Book] to identify which headings in the CSV file contain the name and e-mail address to use in the Public Address Book.
    NOTE: If the CSV file contains names and e-mail addresses only, the file may map automatically.
  12. Click on the [Display Name] drop-down menu under the Imported heading. Select the heading that corresponds to the data you wish to use as the display name in the address book. The data you selected will be displayed in the Imported Sample field.
  13. Click on the [E-mail Address] drop-down menu. Select the heading that corresponds to the data you wish to use as the e-mail address in the address book. The data you selected will be displayed in the Imported Sample field.
    NOTE: If you are using a DC460|470|480|490, and if the CSV file does not contain a heading row, the drop-down menu will contain information from the first line of data in the file. For correct Public Address operation, the display name must map to a user name and the e-mail address must map to an SMTP format e-mail address, for example, name@domain.com.
    If you are using a DC425|430|432|440 and if your CSV file does not contain a heading row, the first row of data will be lost.
  14. Click on [Apply New Settings] to save any changes.
    NOTE: If you click on the [Clear All Addresses] button all entries will be removed from the current public address book.
  15. Click on the [X] in the upper, right corner to close Internet Explorer and return to the desktop.
Sep 23, 2008 | Xerox Office Equipment & Supplies
Converting plam address book to my Htc pocket pc
method1: The easiest way to do this is to sync your Palm Desktop data with the PIM on your Yahoo account. It's free so if you don't have a Yahoo account sign up and get one just for the transfer. Once your DateBook data is on Yahoo there is a simple to use option to sync Yahoo to Outlook. once all your stuff is in Outlook it will ActiveSync to the PPC
method 2:  install the Outlook and then the Palm sync conduits and sync their datebook, notes, tasks and contacts to Outlook. install Activesync and sync the pocketpc and they get their data. you can also use pocket mirror software for this.
method3: Install ExtendConnect from Extended Systems. Then sync first with the Palm. Then sync with the Pocket PC.
Jun 17, 2007 | HTC P3600 Pocket PC
Palm Tungsten C Handheld Logo
501 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
