Question about Kenmore 91245 Compact Refrigerator
No Workie I had a large build up of ice in freezer, door was left open . So I removed the ice and now the only thing that is working is the light. Also the compressor is hot. Thank You Richard
  • rdillon Sep 11, 2008
    Hello Wouter, or Speed boy, I did not use a sharp tool ****! After your posting I lowered the freezer tray to see that I did flatten the raised surface in a few spots pinching the gas routes. So is this thing junk now ?
    Thanks for the imfo.
    rdillon
  • 76 Answers
How did you remove the ice?
If you did it with a sharp object you may have damiged a gas pipe line and thats way its not cooling...
Let me know plz...
Wouter
Posted on Sep 11, 2008
  • Wouter Frylinck
    Wouter Frylinck Sep 18, 2008
    hA HA NO MAN, YOU CAN HAVE IT REPAIRED,you get a thing on the market called GREEN STICK.
    you use that to cover the hole with,but you should have a repair man do that,then a re gas and your done,its not too expensive so go for it..
    Later
    Wouter......
If your fridge is left open over night and it wasnt closed till morning and the alarm light does stop flashing when it is closed what does that mean?
Hi and welcome to FixYa, I am Kelly.
FYI... The door alarm will sound anytime the door is left open for more than 4 minutes.
Per your post... What it means your refrigerator is working normally.
However... there is the possibility of having excess ice build up on the evaporator coils from the door being open all night. If the freezer section starts warming up due to poor airflow you may have to do a manual defrost. You would first notice the lack of ice production or soft ice cream if there were air flow problems due to excess ice on the evaporator coils.
To do a manual defrost all you do is:
1. Unplug the unit
2. Remove freezer contents
3. Use a fan directed at the freezer compartment for just over 2 hours (makes a water mess)
4. Reload the freezer
5. Plug in the refrigerator
Everything should be back to normal in just over 4 hours except ice production that can take up to 8 hours.
Thanks for choosing FixYa,
Kelly
Nov 21, 2010 | Whirlpool Refrigerators
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
Error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Jul 20, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Samsung RS2556SH Freezer left open. compressor does not come on.
if door was left open for some time, there may be excess ice build-up on the evaporator which may take more than 2 hours to clear. two methods to cure switch off and leave for 24 hours with doors open. or remove back panel in freezer and carefully melt ice off with a hairdryer
Jun 16, 2007 | Samsung RS2556 Side by Side Refrigerator
Kenmore 91245 Compact Refrigerator Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
