Question about Sony KP-57HW40 57" Rear Projection Television
Pain in the +++
The sreen will have a series of yellow flashes for about 10 minutes and then go dark, then the stand by lite will flash, no sound either. thanks, larry
    Problem Solver:
  • 18 Answers
You need to post more info about this problem. How many times does the led flash ? This could be a simple raster adjustment from the front of the set.
Posted on Mar 11, 2007
  • 513 Answers
I can't give you a "replace this or that part" diagnosis, but obviously its broken, on a level that takes a repair technician to fix. But you get surprises on fixya, hang around and someone might come along who has seen your symptom. That might give you an idea of the extent of repair needed, but I would suggest against opening the set yourself unless you know what you're doing. TV's store voltages(even after plugged out) that can kill. Good luck
Posted on Apr 23, 2006
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Continuous Red Eyes and dark photos every other one.
1) The red eye effect is due to pupil dilation. When the person is standing in dark, the pupils dilate to allow more light to enter the eye so that objects are visible. In such conditions if you try to take a snap then you might end up having Red eyes.
What Red eye reduction technique does is that it flashes a series of times before the actual snap is taken and due the series of flashes, the pupil try to adjust by closing down and reducing the red eye effect, hence stronger the flash, less is the red eye effect.
Also, there are bundles of software out there which can detect red eye and remove the same.. I am not sure, you might have received software even along with your camera that can address this issue.
2) The use of Speed-Lite 430 might not be always .. It depends on the conditions and distance of the object from the camera lens. Onboard lite should be enough to capture the subjects that are within 5-6 meters and to get rid of shadows where as if the surroundings are very dark then you might want to fallback on Speed-Lite 430.
3) The basic difference between the RAW and JPEG is that RAW is uncompressed format and you can do editing and compression at later time where as JPEG is a compressed format and you might not be able to do as much as you can do with RAW format. Unless you want to edit the images at later stage, you might not want to use RAW.
Please let me know if any further explaination is needed.. Till then Happy Photography :)
Regards,
Srinivas
Apr 03, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
Sony KP51ws520
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Feb 21, 2009 | Sony KP-51WS500 51" Rear Projection...
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
