Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Printer is not printing at all, just blank pages
I am having trouble with my printer. It does not print anything at all. Even with the top open, it only prints white pages when printing, copying or faxing.
I have tried rebooting the printer and computer several times with no luck.
Do you have any advice for the next steps to try?
Thank you for your assistance.
Jennifer
    Guru:
  • 859 Answers
I can help you troubleshoot your printer. Just be prepared if your printer never prints again. This is rare to say the least. I just want you to know that in advance. OK? Laser printers use a static charge applied to the paper to represent your document and then this charged paper passes over the toner and finally the toner on the paper passes under a tungsten wire heated up high enough to melt the toner into the paper. This is why newly printer pages are warm to the touch. So, with three systems doing the magic any one of them can fail due to fatigue.
To start with, when was the last time you changed the toner cartridge?
How old is your printer and how many pages per month has it printed so far, on an average?
Are you under warranty any longer?
Thanks.
Worldvet
Posted on Sep 11, 2008
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
For no reason at all, my printer is printing blank pages from ANY program I use, including when I select the HP Printer Test Page. I even put in a new print cartridge. WHat the heck hapened???
check front cover.
There is a small plastic piece wich is pushed the door of lasser scanner assy(LSA) (left upper side of the top cover). If this plastic piece is broken he cant push (to open) LSA door and you will take blank page ever when you print...
Jun 21, 2010 | HP LaserJet 1320 Printer
I cannot print anything from my printer it prints blank pages how do i troubleshoot
Click Start
Click Control Panel
Click Printers
Click with the SECOND (usually the RIGHT) mouse-button on the icon for your printer.
Click Properties
Click "Print Test Page"
If it prints a "blank" page, then either your printer is broken, or it is out of ink.
Take the printer to a qualified technician for trouble-shooting.
Nov 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Apr 12, 2009 | HP DeskJet 842c InkJet Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Paper is rolling through
clean the paper rollers with water...let dry, then send a sample page through..no print necessary. just print a blank page.
Jul 04, 2008 | Compaq Inkjet Ij1200 Printer
Prints only the 1st page of info. sent by adobe.
No, it is definitely your printer. You need to uninstall it and reinstall it to correct issues.
Nov 18, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
