Question about Mitsubishi The Big Easy TV
Goes dark The light sensor on the front of my 1998 mit.big screen makes my picture go darker than it should and I cleaned the sensoe both inside and out side and it still does it, can you help ?thanks Fred
    President:
  • 3,130 Answers
Turn off the sensor then Its should be a switch or in the main picture menu. These sensors do go bad but its rare . The problem here is usually a misajust of the sensor or a defective sensor But like I said there should be an off for it.
Posted on Apr 21, 2006
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Dim/dark Picture
The model indicated here is rear projection that uses three picture tubes.
If rear cover is removed--can be done by removing entire front screen but there are hazards like damaging the screen---with rear cover removed clean the lens in the three round cyclinders which point up and are hard to miss===
They are the light source for the picture---there is if you look up inside and to the rear a mirror but unless grimy it rarely needs cleaning.
clean the lens with a lens cloth or even a paper towel with glass cleaner sprayed on the towel.
Jun 12, 2012 | Pioneer PRO-520HD 53" Rear Projection...
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Optical Engine in a Mits WD-52527
You have to be careful when replacing the projection bulb assembly. Don't aways look for the cheapest as they are rip-offs that do not last long and are not as bright. Dont buy OEM "compatible" only OEM originals. Call Mits Customer Service for advice
Apr 26, 2008 | Mitsubishi WD52527 52" Projection HDTV
Dark bottom half of screen and dark patch in corner
Thanks for the picture - that's a big help.
It looks you have the dreaded light tunnel collapse common to all LG1.gif DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps.
Hope Ya Fix It!
Jan 24, 2008 | LG RU-44SZ51D 44" Rear Projection...
Dark picture (projection tv)
Hi Steve,
The picture is darker because the dust build up on the lamps or CRTs. I would suggest to leave the TV unplug overnight and clean the lamps using a screen cleaner that works better then windex and clean the mirror that reflects the video to the screen if you can get access to it.
Mar 11, 2017 | Televison & Video
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Screen goes dark
I thught I answered this one but if you disconnet the sensor it should brighten up the picture If it dosent then its part of the brightness curcuit and must be replace. As I remeber thewre are severall models that you could simply disconnect. Or there should be an auto brightness feature in the main menu picture ajustment to simply disable or shut it off. Good luck
Apr 22, 2006 | Mitsubishi The Big Easy TV
Televison & Video Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
