Question about Maytag 24 in. MDB4100 Built-in Dishwasher
Door opens beyond position parellel to floor
The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
  • dougjsommer Sep 20, 2008
    Thank you. I really wanted to do this myself. I am not sure this 10 1/2 year old dishwasher is worth the cost of a service tech but I don't want to create a nightmare for myself either.
  • dougjsommer Sep 22, 2008
    You rock Harvey! I appreciate this candid advice. I just might attempt this and take you up on the live chat.
    I can tell you this much for sure. My wife let my play on the open door for a while before I put an end to that practice. Whatever is broken in there is the result of too much weight on the open door.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi dougisommer
I'm Harvey the Master Plumber.
Your question is: The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
You may need a sevice tech for this. The 'door catchers' on the sides of the unit can only be accessed after removing. Not a job for the inexperienced.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
  • Harvey Goldberg Sep 21, 2008
    Hi again dougisommer,
    I agree with you but if you feel you can fix it yourself, you will need a special tool called a "basin wrench". We could also schedule a live chat at a convenient time for both of us so that I might guide you through it. Only attempt this if you feel you have enough expirience. Honestly, it took me six months installing d/w every day to get good at it. Even so, we may get the d/w out and find out that it can't be fixed, depending on what's wrong. But I'm willing to try if you are.
    Please give me a rating here at fixya before you sign off
    Thank you,
Door opens beyond horizontal hitting floor
There may be a second mounting hole on the hinge to reposition the spring but more than likley you have broken door cables
Mar 05, 2014 | Jenn-Air JDB1095AW Built-in Dishwasher
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
I have just bought a 2006 used Honda Odyssey and, to my dismay, realized that if the van is parked on any incline, the driver's side (manual) sliding door will not stay open. (Passenger side is fine.) Do...
The sliding door lower roller latch most likely needs to be replaced. It has a spring powered latch that should hold the door open. This spring is probably damaged or broken.
It should be possible to mount a factory roof rack by removing the roof trim molding and the interior headliner. Roof rack hardware would have to be installed from the inside, then new roof trim molding (with sized cut outs for the rack hardware) would be mounted outside. The new rack would then be able to bolt up. The headliner would then be replaced. Possible but maybe not very easy.
Mar 21, 2011 | 2006 Honda Odyssey
Door sprung?
remove bottom cover. look for an arm at bottom corners. should be two springs attached to give tension. probably got a broken one. drawer rolls out
because door opens farther than it should.
May 21, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Soft drop door mechanism came undone The soft drop door tub wheel
It's held in place by a soft drop nut (99002192). If damaged, the tub wheel part number is (99002183), and the soft drop bolt is (99002189).
May 02, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Diswasher detergent door
lizzie1 First thing check if the lower dish rack is in right position. If it is in wrong position it is not enough room for the lid to pop up open. Try to turn the dish rack around and see if it works. If not, then I'll need the full model number for your dish easher. Gendos...post back
Jan 28, 2007 | Whirlpool 24 in. DU850DWG Built-in...
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
269 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
