Question about Home
Shower pressure. The presssure on my triton t80i shower has dropped by half.Pressure light is now of on shower cover. Any ideas please,THANKS.
    Novelist:
  • 171 Answers
Hi chicken69
I'm Harvey the Master Plumber.
You want to know why the presssure on your triton t80i shower has dropped by half?
It is very possible that some debrie has come up in the water and is partially clogging the shower. For this you would have to turn the water off and dissassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
I have a problem with my triton shower.i use this shower for 9 months everything was ok but now to get warm water I have to turn the dial to 9 or 10 and it just a little warm and the pressure is very...
Since I am unsure of the model you are using I would suggest you go to their site and check the FAQ's and support information. You can select your info in the drop down boxes and go from there:
FAQ Triton Showers for the Homeowner
I hope this helps.
Jan 29, 2015 | Home
Is it a mains fed shower
The installation must be in accordance with
Water Regulations/Bylaws.
To ensure activation of the heating elements, the
shower must be connected to a mains water
supply with a minimum running pressure of
100kPa (1.0 bar) at a minimum flow rate of eight
litres per minute (nine litres per minute for the
9.5kW rated model).
For all units the maximum static pressure must
be no greater than 1000kPa (10 bar)
If in any doubt, the pressure should be checked.
Sep 16, 2014 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
655 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
