posted by surfinrick on Apr 21, 2006
4 some reason my hdtv only works 4 a second with a scrabled screen and then goes 2 unuseable signal can u help me? can u tell what my hdtv signal would be because the component i am tring has three setting 480,720,1080. i hope my t v will be compatable thank you 4 the help
Comment by surfinrick, posted on Apr 21, 2006
hello techman are u saying that my t v is not compatably in the hdtv mode
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 15, 2008
I have a 50 in HDTV model number M50WH925YX1 and the scren will come on the TV will go on and off by itself...the picture goes in and out...what is the problem and how do I fix it...it does this every 2 or 3 days
Best Solution
The unuseable signal is a common thing that rcas do when the input rf signal is No good . You could have a bad cable line an bad ant. line or a bad tuner or the set is switched to the wrong anttenna input. No for a Hd compatable componet I always start with 1080i and go from there cause thats what is needed for an hdtv set. Good luck
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 17, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I had the same problem and all I had to do is go into the web browser settings and click on "reset". I have no idea why this would have anything to do with correcting this, but it worked for me and I read this as a solution on another question-solution site.
Suggest a new solution for this problem
Post a New problem for RCA P52926 52 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
RCA P52926 52 in. Rear Projection Television
black horizontal line moving...
I have a PIONEER rear... Answer This...
RCA P52960YX1 power supply dead...
I have a P52960 rear projection... Answer This...
turn off and on but doesn't...
well turned on the tv set today... Answer This...
tv turned off and started...
I had turned my big screen tv... Answer This...
RCA 46 inch convergence problem
I have a 46" RCA rear... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
