Question about Yamaha DVXS60 System
Pulsing screen While playing a DVD in the player, the screen colour pulses. Every two (or so) seconds the screen gets a burst of colour and a slight distortion.
  • 513 Answers
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Posted on Apr 23, 2006
How long is it safe to continuous grind
I burned mine out and had to repair it by trying to grind a pound of beans. I say pulse works the best--2-4 seconds each burst. One can grind 5-10 seconds but it heats up inside and in my case, contact melted (metal) from ongoing current to motor via switch. I rigged it but would recommend staying under 10 seconds. pulsing works best in coffee grinders and food processors.
Jan 20, 2013 | Braun KSM 2 Electric Blades Grinder
I have an older 100,000 btu Reddy unit that was pulsing. Put new diesel in and problem went away for awhile. Now pulsing again.
might have a clogged fuel filter. try to drain and replace. run fresh fuel. the pulse also could come from too much fuel causing a burst in the main heat exchanger. if this heater is older than ten years i would trash it and buy a new one so you dont blow up
Sep 12, 2009 | Reddy Portable Forced Air Propane Heater...
Pulsing/skipping picture on Sony Bravia 52'' LCD flat screen TV.
Yes it sounds like a lemon. A firmware update is the next thing to try.
Apr 28, 2017 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Pulsing screen
It sounds like the TV is responding to copy-protection on the DVD. Do you have the player connected through the TV's antenna input on channel 3 or 4 (RF connection) or through AV inputs on the set? You're probably using AV as most of the newer combo players don't offer RF output. Depending on the way the TV is made, this can often cause the set to display the brightness changes you describe. (The copy protection was designed to make the copy play back that way so it would be unwatchable. Sometimes the TV would be affected the same way on normal playback. It's why companies started selling "image stabilizers" to put between the player and the TV -- or another recorder -- to remove the copy protection. These devices may still be available. I have one but bought it at least 15 years ago.)
Jan 15, 2009 | Sony SLV-D380P DVD Player/VCR
Loss of colour
Hello judithprust
The IC (integrated circuit) that controls color might be bad or the filter for the color burst might be defective. In either case a qualified TV repair person should be enlisted to fix this problem. The color burst signal uses vector mathematics to control the color output of your device, it the color burst is removed the picture will display a monochromatic (black and white) picture.
Thank you,
Shuttle83
Jul 11, 2008 | Panasonic DMR-E55 DVD Recorder
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Yamaha DVXS60 System Logo
136 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
