Question about Dell Inspiron 1521 Notebook
User profile cannot be loaded
When I try to logon it says the User Profile Service failed the logon. How do I get logged onto my system
  • Anonymous Mar 15, 2009
    I cannot get into my computer.
  • Anonymous Mar 30, 2014
    When I try to log in with Password it says User profile Service Service failed to logon.How to fix this ?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
Logon to the Computer
NOTE : Go down the list here until you find a option that will work for you.
1. Logon to another Administrator account.
NOTE: If you do not have another Administrator account, then proceed to step 2.
A) Go to OPTION ONE or OPTION TWO.
2. Boot into Safe Mode.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
C) Go to OPTION ONE or OPTION TWO.
OPTION ONE:
Fix the User Account Profile
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
OPTION TWO:
Delete the User Account Profle
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
1. Delete the User account profile that this error is for.
NOTE: See: How to Delete a User Account in Vista
2. Open the Start menu.
3. In the white line (Start Search) area, type regedit and press Enter.
4. If prompted, click on Continue.
5. In regedit, go to: (See screenshot below step 7)
6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it.
NOTE: It may have .bak at the end of it.
A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.
B) Repeat step 6 until you find the one that you deleted in step 1 above.
NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.
7. To Backup the Registry SID Key -
WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.
A) Right click on the SID key, and click Export.
B) Type in a name and save the REG file to a safe location.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
C) Continue on to step 8.
8. To Delete the Registry SID Key -
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
10. Now, just create a new normal Administrator account.
NOTE: See: How to Create a New User Account in Vista
11. Restart the computer, and logon to your new account.
Good Luck.
Live, Love, Laugh.
Posted on Sep 11, 2008
How do I unlock my laptop? The message is "the user profile service failed the logon" "user profile cannot be loaded"
louise,
click the link below for resolving the error message you are getting logging into your computer.
you receive a "the user profile service failed the logon" error message
https://support.microsoft.com/kb/947215/en-us
thank you,
dell-jesse l
dell social media and communities
Jan 21, 2015 | Dell Computers & Internet
Asus k53u accepts password then comes up the user profile service service failed the logon user profile cannot be loaded How can I get round tis problem ?
Start in Safe Mode and then do a system restore back to a date when it was ok. If that fixes it, immediately create a new restore point and name it Profile OK. (Just in case you get it again) This fault has been occurring for months now and usually after an MS critical update! Good backup strategy is paramount.
Sep 04, 2014 | ASUS K53UA1 Notebook
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
Dell Vostro 3500 running Windows 7. Trying to log into the admin (only) account and get the message: The User Profile Service service failed the logon. User profile cannot be loaded. No Recovery Media was...
Please check following link from Mocrosoft knowledge base:
Error message: "The User Profile Service failed the logon. User profile cannot be loaded", when logging on to Windows 7 or Windows Vista
http://support.microsoft.com/kb/947215
PS: If it helps then please click on thumbs up.If you need more help then please let me know.
Sep 20, 2011 | Computers & Internet
Buenas noches, apenas enciendo mi portatil dell 700m me pide clave de bios, la lleve a un tecnico y creo que no la trabajo bien y no la logro desbloquear, que puedo hacer?? soy de colombia y la verdad no...
Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
The easiest way to recover from a lost password situation is to use a password reset diskextlink.gif. If you have a reset disk, follow these steps:
  1. At the Windows logon screen, click Reset password.
  2. Insert the recovery diskette or USB key.
  3. Follow the instructions on-screen to create a new password.
  4. Log onto the account using your new password.
new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Issue 3: Resolve Error: The User Profile Service Failed the Logon
The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
"Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be loaded"extlink.gif Article ID: 947215.
Issue 4: If You do not have a Password Reset Disk
If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Nov 07, 2010 | Dell Inspiron 700M Notebook
When i open my computer theres an error the user profile service failed to logon user profile cannot be loaded
Logon in safe mode.
  • Restart your computer and log into safe mode: As your computer is rebooting, press F8 Repeatedly after your POST screen.
  • Choose safe mode with networking
  • Open internet explorer and copy and paste this site into the address bar:
http://www.thewindowsclub.com/fix-the-user-profile-service-failed-the-logon-user-profile-cannot-be-loaded
  • Click on Microsoft Fixit.
If this resolves your issue, 4 thumbs would be appreciated.
Sep 16, 2010 | Computers & Internet
My laptop wont let me log on user profile service service failed to log on
U can try login in to the same user account in safe mode or try login in a different profile from there see if u can make any chages in the account of if the data there is intact. For further resolution u can visit this website.
Apr 25, 2010 | Sony Computers & Internet
Dell Inspiron 1521 Notebook Logo
1,882 people viewed this question
Alun Cox
