Question about JVC KD-AVX1 Car DVD Player
HEEEEEELP!! My wiring harness does not have the wire for the parking brake, but my radio keeps flashing parking brake, and won't play dvd's, just spits them back out. What do I need to do.
  • 3 Answers
Just hook it to the same ground as the cd player
Posted on Dec 02, 2008
    President:
  • 1,450 Answers
This wire is designed to be grounded when oparking brake is on this is so you cannot watch dvd while driving as that is illegal. Some people wire this up on a toggle switch to a ground so they can flip the switch and make it work whenever they want. I cannot tell you to just wire this to a ground as that would be illegal!!!!!! ;) supposed to wire it to the switch on park brake this wire grounds when brake is on
Posted on Sep 11, 2008
Kenwood How To Connect
the wire that is marked "connect to parking brake" is a normal earth wire so you don't have connect it to the parking brake find a good body earth and connect it [make sure it's secure] you will find this wire on the wiring harness it's usually brown.goodluck
Nov 26, 2013 | Audio Players & Recorders
Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Sep 24, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
How to install my Alpine in my 2001 525I BMW also how to by-pass the wires that allow the DVD to work without the e-brake on.
to install it you need to buy a dash kit for your car from walmart or amazon.com then you buy for your model and car the wire adapter kit. plain and simple from there. colored wires connected together easy as plug and play. to by pass the e-brake you need to buy a relay.
here is something i wrote up awhile ago for a buddy to bypass his after he took pictures of his model back.
On the back on the unit there should be an additional wire labeled as the "Parking Brake" or something to that effect. Law implies that this should be spliced into the Parking Brake wire (which is essentially a constant hot which becomes a ground when engaged). So the obvious thing here is to simply ground the Parking Brake wire on the back of the radio. This can be done just splicing it into the black wire on the radio harness.
found another solution from ehow for you
http://www.ehow.com/how_4482151_ebrake-screen-dash-dvd-player.html
let me know if this helps
Mar 20, 2011 | Alpine INA-W900BT Car Video Player
How to play dvd video when driving my car
Most wiring harnesses have a solid orage wire for illumination of the radio2_bing.gif and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal. Just remember to be safe and pay attention to the road. Oh, and most states have laws governing the use of video playing in plain sight of the driver. BE CAREFUL!
Apr 22, 2010 | Kenwood KVT-512 Car DVD Player
Is the park signal wire supposed to be hooked to the ground side or power side of parking brake switch? I'm trying to install a kvt 512 for a buddy, and the dvd player wont work with out the park signal.
If you want to by-pass the parking brake wire, here's how.
Apr 13, 2010 | Kenwood KVT-512 Car DVD Player
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
Bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
Apr 09, 2009 | Kenwood DDX-512 Car DVD Player
How can I get DVD's to play
u need to find the wire for the brake and plug it in to the parking brake or get a bypass for it otherwise known as a cheater harness u can get them online
Sep 11, 2008 | JVC KD-AVX1 Car DVD Player
Parking brake
If you have the VM9410 then there is a way to play dvd's even when you are driving. You must ground out the pink wire in the harness. This allows you to watch dvd's even when driving. good luck!
Feb 24, 2008 | Jensen VM9410 Car DVD Player
Panasonic CQ-VD7005U in dash dvd 7'' touch screen
Connect the light blue parking brake wire coming out of the back of the radio to the black ground wire also out of the radio to the black ground wire on the wiring harness.... Basically just ground the parking brake wire.. Itll work, I promise. I have the 7001u.
Dec 03, 2007 | Panasonic CQ-Vd7001U
JVC KD-AVX1 Car DVD Player Logo
293 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
