Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Umpossible to take pictures
My camera's playback works, but when I try to switch to video or thetaking picture function, it beeps five times, and the screen goes black. The lens is retracted. So the camera does not takepictures or video, only shows the pictures that I have already taken.How do I get the lens to extend and the camera to start takingpictures? The camera hasn't been abused in any way according to my ownknowledge.
  • 129 Answers
Might seem silly, but have you checked the batterries?? The beeps usually signal a loss of power, if not check shutter is not jammed with dust particles, use compressed air to shift it.
Posted on Oct 02, 2008
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
mode.
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
Camera beeps five times, doesn't work
the beeps mean the lens can't be opened or closed. maybe something stuck or it's just failed?
Aug 30, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Playback problem
Video Head is dirty/ clogged. Use good quality Video Head Cleaning Cassette.
Jun 08, 2008 | Sony Handycam CCD-TR517 Camcorder
No video playback
Sounds like a classical video head problem. May be quite expensive to fix. Of course you can first try spraying the head with a "no residue" contact cleaner and then dry it out with pressured air to see if that fixes the problem.
Jan 07, 2008 | Canon ES50 8mm Camcorder
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Won't turn on in Picture Mode
I have the same problem - 4 fast beeps and it turns off. My guess is that the lubricants are getting old and sticky - I had a Canon SLR that developed the same problem after being in the extreme cold. Here's a couple of things to try:
  • You can still access the picture review features by holding down the review button while you turn it on (note that if you hold down the trash button you'll see the firmware version.)
  • What doesn't work: Resetting the camera from the setting menu; replacing the battery, replacing the SD card, cursing.
  • I've been able to consistently get it to function normally by hitting the camera into the palm of my hand on the left side (with the viewing screen facing you), just after turning on the camera.  If this doesn't work, keep hitting harder until it works.  Once on the camera works normally.
Jul 02, 2007 | Pentax Optio W10 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Problem with image
What mode is the camera in? is it in "Auto" at the top there is a dial switch it to auto and press button halfway (shutter button) when you press the button halfway the camera will beep and display a square box on the LCD. If the camera beeps once and the box is orange it could not focus and you need to retry pressing halfway again. When it is in focus it will beep 2 times and it will show a GREEN box. This is the indication it could focus on the subject correctly. Its a machine and sometimes it takes it a bit for it to figure out what your wanting it to do. Its the nature of the unit
Apr 03, 2006 | Canon PowerShot A85 Digital Camera
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
